Removing Overdrive Shaft Lever Pin
S
Sal36
Group,
I have an 1961 AH BT7 with a leak coming from the lever shaft on the right side of the overdrive. It appears easy to change the O Ring seal, but in order to do so you have to remove the pin holding the lever onto the lever shaft. That seems like a simple job of using a punch to push out the pin. However, the pin just won't budge. In fact, I bent the punch. I also tried heating up the shaft, lever, and pin several times, but it still won't budge. I know that I can drill the pin out, but I am very hesitant to do that because I am such a crooked driller that I know that I will screw up the shaft and the lever. Does anyone have any suggestions on how to remove that pin?
Sal
Keoke
Nope: I was going to suggest all the things U have already tried????
IIRC, it's a solid, tapered pin; have you tried driving it out from both directions? I replaced my O-ring with a square cross-section 'O'-ring a while back; I replaced the tapered pin with a roll pin.
S
Sal36
Bob,
Thanks for the information on the taper of the pin. I did not know that. I only tried extracting the pin from the top down. I won't be able to get down to my shop for a few days but as soon as I do I will try extracting the pin from the bottom up. I will report back.
Thanks, Sal
S
Sal36
Bob,
Thanks, Sal
Bob,
I did make it down to my shop and I tried driving the pin out from the bottom up. No luck. It looks to me like my only alternative is to very carefully drill the pin out. Do you have any other suggestions or advice on drilling out the pin?
Sal
Sorry, can't help; I'd probably try penetrant, heat, etc. a few more times, though. I've usually made a mess when I've tried to drill out a stuck bolt, pin, etc. I'm surprised it didn't come out, though; mine came out relatively easily (the tapered pin on the clutch slave fulcrum shaft was a different story, however).
S
Sal36
Bob
Thanks for the reply. I think I will wait until I take the transmission out of the car. I have to remove the overdrive anyway to change some gaskets. When the overdrive unit is up on the bench I will get much better access to the set pin and better leverage on it. Thanks again, I will let you know what happens.
Sal
Keeping the bit centered is the hard part; if you have access to a drill press that should help. I think those pins are made of a hardened steel, but this particular one isn't under much stress; it just keeps the 'adjustment' lever from falling off.
71tr Removing Stuck Overdrive Unit Triumph 3
Johnny Removing Overdrive from transmission. Austin Healey 1
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
