TR4/4A Removing the Differential
KVH
I'm not seeing how I can do what the Manual says to remove the differential. Should it just slide out one side above the frame member? The passenger side has slightly more room due to the absence of a protruding brake clip on the driver's side. The manual talks of sliding the unit in one direction, then tilting the unit and coming under one frame side, then lowing the other side to remove. I can't do that. Not enough room, and my muffler pipes were welded. I'd apparently need to cut the pipe, but if I did cut the pipe, I seriously cannot see how that provides more maneuvering ability. Any ideas?
Merlin63Tr4
What TR are you working on?
M.
Merlin63Tr4
I did this on my '63 TR4 and the manual's procedure does work.
As you well know the TR4A frame and exhaust system are different than the TR4s, so partial removal of the exhaust system might be required.
If I remember correctly this is what I did on my ’63 TR4, I believe it follows the manual's procedure pretty closely (it’s been awhile since I did this).
Undo the driveshaft rear joint and stow driveshaft out of the way
Loosen the rear of the exhaust system at the rear hanger
Remove the brake drums
Undo and remove the parking brake linkage and cables from the rear axle
Remove brake shoes, springs, etc
Undo and remove brake lines and hose from rear axle and brake cylinders
Remove axle shafts, brake backing plates and shims (keep track of location and number of shims)
Undo the rear shock links (might have to remove shocks, don’t remember)
Undo and remove U bolts and distance pieces
Rotate the rear axle (gravity will do it for you) to a nose down attitude
Slide rear axle toward driver side (left side) until you are able to lower the passenger side (right side) axle tube under the right frame member.
Then slide the rear axle assembly towards the passenger side until you are able to lower the driver side axle tube under the left frame member.
Remove rear axle assembly from under vehicle.
M.
KVH
KVH
Thanks for the reply. While that sounds OK, my exhaust wouldn't move down much at all, and I couldn't see the manual method working. However, it did get it out.
It goes out over the passenger side frame member, above it, but you must rotate so the differential shaft faces the rear of the car. Came right out. What a load of goop, grease, grime and filth.
Now my decision is whether to just replace the leaking seal, or to take it to a diff shop for inspection. Any advice there? I have no reason to suspect problems, and I don't want a $500 bill for just looking, but I just bought the car and the diff gear lube looked like new. Suspicious since it also clearly was leaking.
Can I take the cover off, take a look inside, feel good about what I see, replace the seal and be happy, or is an inspection by a pro really needed now?
Merlin63Tr4
Was the diff making grinding or nasty noises?
If not I would just take off the rear cover to give things a good cleaning and a visual inspection
Look for hairline cracks at the root of the gear teeth, chipped teeth, etc
Replace the rear cover gasket, the leaky front pinion seal and call it a day.
Don't forget to inspect the pinion flange for excessive wear where the seal rides.
M.
KVH
KVH
Good advice. Thanks. I forgot about that flange. I understand a sleeve is made for that, just like for the front pulley.
Merlin63Tr4
Oh and don't forget to mark the pinion nut position and count the number of turns as you remove it to be able to return the pinion preload to it's setting.
Specially important if you have the collapsible type spacer to set the preload....
M.
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
J Removing the differential from early BJ8. Austin Healey 37
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
T TR4/4A Removing wiper motor - inner cable Triumph 4
