TR2/3/3A Can radiator be fixed without removing it?
Momikey
Can a small leak be fixed on my radiator without removing from the car?
M
Momikey
How do I remove the front apron to get the radiator out. Is there a video or list somewhere showing me how to get it off of the car?
charleyf
I had the same problem once. The guy at the radiator shop told me to pull it out and bring it back for him to repair it.
Removal is to remove the front bumper, bolts above the radiator across the top and down both sides from the underside of each fender. Time consuming depending on how hard it is to remove the bolts from under the fenders. They have a tendency to be rusted and stubborn. When you put them back on use never seize on them.
Charley
GTP1960
Once you take the apron off, you will probably find several more things that need doing.
Removing the apron can be like opening Pandora's box!
BillyB62
I totally agree with Guy. I started out planning on just installing a "hurricane" fan from Macy's Garage (which is AMAZING BTW), and ended up with a new radiator, motor mounts, front wiring harness...among other things.
M
Momikey
Well I want to do an alternator conversion and add a elec push fan so I guess I will do it all.
Do you guys think the Radiator can be fixed or should I get a new one?
Geo Hahn
The leak at the seam for the neck is a common one (people push down on the cap as the open or close it w/o supporting the neck). Definitely fixable but you will want the radiator checked out while it is at the shop. Some have also added some reinforcement to that neck (Randall, I think did this).
...Removing the apron can be like opening Pandora's box!
But remember that after all the evils escaped from the box there was still one thing left at the bottom.
M
Momikey
Hey Bill does the Hurricane fan work really good. Do you think I should put one of those on my TR3A instead of the push fan on the outside of the radiator? (110 degrees today in Cali) Also did you have to buy the mounting kit on the macy's site has well to go with the fan?
charleyf
The one I had repaired at the neck like yours is still on the road 9 years after the repair. That car is now in Washington state with my son. I will add that on my 2 TR4's that I have built I have converted to the aluminum radiator. We get the very hot temperatures as well.
Charley
GTP1960
Is it overheating?
if so an aluminum rad. W/ out the crank port is a good option.
i went with a puller, but their are as many reasons to pick a different fan as there are members of BCF.
and they all work.
also consider replacing water pump while your there.
(steering & front suspension will be calling your name too, awa: timing chain & front seal.)
TexasKnucklehead
Be careful, here's what I found after removing a few things that needed attention. It needed attention too, but I still had hope. -And that's not to say all the evil has come out...
M
Momikey
Oh No. My engine only has 6000 miles on it so I hope I don't strip it down that much. LOL.
CJD
I had just such a leak in a radiator rebuilt from a local shop. You can read the thread, but basically, when faced with several hours R&Ring the rad, I chose to solder the leak in place, even though the radiator had a warranty on their work. Took 20 minutes and lasted since then. I doubt a radiator shop would fix it in place, as it opens them up to a lot of liability if they screw up with the torch in tight quarters. Plus a shop could care less about the work YOU have to put in.
https://www.britishcarforum.com/bcf/showthread.php?79899-It-s-Alive!-TR3-Generator-amp-Rad-Questions
M
Momikey
Awesome I'm going to give it a try. So you used standard solder and flux? Did you use small torch to heat up then put solder on or did you use the solder type gun?
sp53
John beat me to it, but I think you could fix that one in place. When I was twenty, we put on metal gutters that were soldered in place on 2 and 3 story + house with large irons and salomoniac to keep the irons clean. John’s posts are very detailed so you will get the scoop there. I would just say that I would use 50/50 solder (and around here that solder has to be purchased in the electrical department) plus get everything squeakie clean, dry and not too hot.
CJD
Like Steve said...cleaning is the key. I just used regular modern solder/flux from Lowes and a torch, but an iron might be easier to control to prevent any colateral damage. The good thing is that if it doesn't work, you can still remove it to go to the shop and it'll cost the same.
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
D BT7 radiator Austin Healey 1
M Radiator Paint Austin Healey 20
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
JFS TR2/3/3A Radiator fan temp probe Triumph 3
