TR4/4A Removing Glass Windshield
KVH
I just not recalling. You push out forward, but do you cut the rubber gasket first anywhere? Just push like a gorilla? Prying at a particular location? I did this 12 years ago, and hard part was reinstalling but I don't remember how I got the glass out. Any, by the way, is it easier or harder if the entire windshield assembly is first removed from the car?
Geo Hahn
I assume either the seal or the glass is going to be replaced, else possibly no need to remove.
I suppose it depends on whether you hope to reuse the seal. I removed mine with a carton knife - easy.
In addition to reusing the seal, your technique may vary if you hope to reuse the windscreen as I have seen it done with someone seated in the car with both feet against the glass.
I would think anything you do 9esp if working solo) will be easier with the frame is still attached to the car. I had the frame and glass out and took it to National Auto Glass with a new seal and they installed it for me -- but it wasn't easy with everything loose.
trrdster2000
KVH, like Geo, carpet knife and run around the edge on the outside. I just felt for the glass and went straight in and slowly cut it all the way round, then go under the rubber and cut the thin part that remains, after you get the first couple of inches up it may just pull off, then the windshield should come right out, with hardly any effort. Then the seal will pull out and your are ready to sand and refinish the frame. Don't forget the 7/16 bolts on the sleeve on the side, they need to be loose also, besides the 9/16 ones on the studs.
Wayne
Popeye
Bronze
Cut the gasket, as folks have said. The gasket has an "H" cross-section. I cut the gasket off on the outside of the windshield, leaving the inside in place, and the glass did not drop inside the car.
While it should be possible to remove without cutting the gasket, the gasket is now 12 years old and more brittle than when new.
Be careful of the paint underneath - while any scratches would be invisible (i.e. covered by the gasket), you don't want any bare metal to give rust a starting point!
bighealeysource Removing glass from 100 -4 windscreen assembly ??? Austin Healey 6
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
Guinn Removing windwing glass MG 8
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
