TR2/3/3A Removing WD-40
Redoakboo
I am restoring a 1954 TR-2 and have stripped all the paint down to bare metal. A body guy said if you are not going to paint the parts right away, spray them with WD-40. It will prevent rust from forming. Now it's time to start restoration of the parts, what is the best thing to use to remove the WD-40 from the parts?
Dick
poolboy
The owner of the paint and body shop that I've used won't even let a can of WD 40 into his shop ...so one of his employees told me....something about messing up the application of paint...but if your guy say's it's OK, I'd imagine something like acetone would be effective.
Bruce100
I know it is next to blasphemy but I have used wd40. (Ok, flame me). I used mineral spirits and/or paint thinner to remove it. I have also used straight motor oil instead of wd40. This was decades ago, so maybe paint has changed since. I got no fisheye or other ill effects in the fi nished paint job. An old time body shop guy had told me to do this when taking a long time to get body work done.
CJD
It's petroleum based, so most of the usual's would work. Carb cleaners, brake cleaners, Kerosene (if you have time for it to fully evaporate), gasoline (if you are careful not to blow yourself up), laquer thinner.
Got_All_4
John hit the nail on the head with Kerosene. There is silicon in WD40 (the WD means water displacement and 40 means it was their 40th attempt). Silicon is a body / painters worst enemy. I'd start with kerosene, get it good and wet, wipe it off and NEVER REUSE THE RAGS you took it off with. Repeat the process and then go to your wax and grease removers. Last and because it does not leave any residue is acetone. You may need fish eye remover in your paint.
dklawson
The normal, regular WD-40 in the blue/yellow containers has NO silicone. They do make a product containing silicone. It is sold in black/yellow containers.
See the WD-40 FAQ page below. They have one that specifically addresses what is in WD-40.
https://www.wd40.com/faqs
As CJD said, normal panel prep chemicals will remove regular WD-40.
sp53
I would use lacquer because a gallon of it is cheap enough and should get into all the places you cannot see by pouring it onto the car outside with a fire extinguisher handy. But, really if you are going to truly restore this car, you will be taking the panels off and blasting them and perhaps using some paint remove or whatever it takes to clean them off, so the lacquer thinner if needed can be applied as you go through each panel cleaning.
steve
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
