TR6 OEM Connecting Rod surprise
hohmanj
In the process of rebuilding a 69 vintage tr6 motor for a winter project.....After removing the pistons from the connecting rods, i found several of the connecting rod holes where the piston pin goes through were mis-aligned.....? The attached photo shows one of the extreme examples but measuring the others with a caliper, they too were slightly off....Is this something I should worry about??
Darrell_Walker
I would check the lengths of the rods. Could be the difference was made up on the big end.
CJD
That is common and not really a problem. The center to center distance will still be correct, assuming the rods are not bent or otherwise damaged. The tooling that aligns the piston pin hole occasionally reads the flash or slight rod twist, and then compensates with a hole that is slightly off center. Frequently the hole will be centered on one side, but off on the other.
When I used to build high performance engines I would go through many rods to find enough to use that were closely centered. On a street engine it will not be a problem. One old head put it to me this way, "Once the piston is at the top, a rubber band will pull it back down"! That's a little exaggerated, but his point was that most of the load on the rod is compression. At the top, even on the exhaust to intake stroke, the air being pumped makes the tension load on the rod very small. Only at racing RPM will the centering be a concern. Power doesn't really change the tension on the rods, but increased RPM will. So stock RPM should not overload even a slightly off-centered rod.
I would frequently find stock rods that had cracks almost completely across one of the pin sides on some of the rods that were severely off center. I realized they were likely running like that for a very, very long time.
H
hohmanj
I confirmed the hypothesis that the rod length between small end to big end were identical 4.330 for all of the rods...thanks for the feedback! On to the next step!
Deleted member 8987
Back many years ago, looking for a new machine shop after a move for my Flathead Fords, I recall a tear down, and transporting all the bits to the machine shop for tanking, inspecting and machining.
This shop did a lot of big engines....including a lot of early Hemi Chryslers primarily for race purposes.
The guy looked in the box, and asked where the rest of my rods were.
I asked why, as there were 8 of them in the box.
His experience was he needed a minimum of 24 rods to find maybe 8 usable ones on Hemis.
I told him to just check the 8 I had.
He was amazed....none bent, twisted, stretched, mis-machined, offset.....nothing.
And in 50 + years of Flathead work, I have yet to have a bad rod.
Knock Wood.
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
M General MG OEM Radio wiring help MG 4
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
C BN1 OEM Rubber Floormats Austin Healey 1
princetn1 MGB OEM Original MGB Chrome Bumpers MG 14
toysrrus TR2/3/3A OEM TR3 Luggage Rack Triumph 7
J Moss OEM AIR DEFLECTOR ASSEMBLY Does it do anything? Austin Healey 9
5 TR2/3/3A Who was OEM glass manufacturer for tr3 windshields Triumph 1
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
S ride difference oem vs poly bushings Triumph 4
T What to do with OEM calipers? Triumph 8
M Help with OEM Jaguar Parts ID Jaguar 5
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
bcbennett OEM side mirrors still available? Triumph 10
Brosky Crappy OEM Parts Triumph 14
G E-Type OEM hose clamps Jaguar 2
C Non OEM/aftermarket parts suppliers. Spridgets 3
B T-Series vintage new OEM MG mechanic uniform patch 4 sale MG 3
V Where to find an OEM hardtop? Triumph 2
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
R TR4/4A CP-Carrillo or Pauter Connecting Rods Triumph 2
R Connecting Rod Big End Specification Austin Healey 4
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
D connecting rod stamps Austin Healey 1
Csarneson Connecting Rod Bolt Question Austin Healey 3
S T-Series connecting rod bolts MG 4
W connecting distributor wires Austin Healey 2
T TR2/3/3A ARP connecting rod bolts Triumph 2
B 1275 connecting rod nuts/bolts Spridgets 7
RedTR3 TR2/3/3A Connecting Rod Bolts Triumph 10
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
Sarastro T-Series TD connecting rod big end diameter MG 4
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
J TR2/3/3A TR3 connecting rod bearing replacement Triumph 11
PatGalvin TR2/3/3A TR3 Connecting Rod Needed Triumph 10
J TR4/4A Tr 3a & TR4 - connecting rod bolt problems? Triumph 11
G MGB MGB Connecting pin MG 5
D Balancing Connecting Rods Triumph 17
Basil Connecting Rod Bolts Triumph 12
C Connecting Rods and Cams Lotus 1
KVH Wellseal and Connecting Rod Place Bolts Again Triumph 2
