Series III E Type
Bruce Bowker
For whatever it is worth to anyone, I just put in a new ignition upgrade kit replacing the distributor, amplifier, ballast resistor and coil with identical units that use the later HE technology.
The car has not run this well since the day I bought it and maybe not since it was new!!
jessebogan
Photos? Info? I am in the middle of installing a Re Opus kit in an XJ12. So far, no sparks. The kit I use comes from New Zeland. So far, the chap that makes it has worked really well with me. I have never seen this car run, so I am working out where the fault is. If the car was not so perfectly original, I would just install a Lucas set up from a mid 80s XJS.
Bruce Bowker
Bruce Bowker
Sorry no pictures. I really can't add much. We simply replaced the 4 old components with the 4 new and the car ran better than great. There aren't any tricks. Each part went straight in. This car has carbs whereas yours I believe is injected. Seems there is a kit specific for each but not sure if that would make a difference with no spark.
Bruce
Platinum
Jesse, You've got pressure at the rail I assume.
No spark would say trigger issue. What amp is tied into this rig?
jessebogan
This is a 74 XJ12L, V12 with 4 strombergs. Whotta oddball, but it is all factory. I am installing a "re opus" kit from New Zeland. It is a new circuit board that replaces the board in the caveman opus box. Uses the same ballast resistor, pick up, ign coil etc.When you order one, you have to tell them how long the wires are, how many etc, so the board is "made to fit the application". I put one in a 76 FI car a couple of years ago, and all was well. In this case, I have never seen the car run. Towed in, some no name coil (that had split open !!), and no spark. New "lucas" coil(made under license...). I have tested it six ways from sunday, and it appears to switch the coil, but still no spark. I took a points distributor, and rigged a circuit to just test the coil, and it has sparks in it.... The guy in NZ sent me a couple of tests I have to run yet, but I had to move the XJ12 out and do some other work. Things are stacked up pretty deep here at the moment. I just sent out a nice 120DHC, I have the XJ12, another similar vintage XJ6, an 89 XJS in for ABS work, a DS 420 l;imo I am in the middle of an engine swap, and some major suspension surgery on a 66 Etype. My plate is overflowing.... Not a bad thing tho.
Platinum
Not bad at all!
And again: if we were geographically nearer, I'd be over to lend a hand sorting out the load!
With the quad Zed-S induction, you've got an oddball indeed! We had a client with one, very early XJ, he STILL drives it daily AFAIK. We put a Crane XR-700 in it IIRC as he was more interested in reliability than originality.
I'll be interested to learn just what you find as the root cause of the no-run.
Knowing ya, I s'pose you've taken nothing for granted with an engine you've never heard running. :wink:
Bruce Bowker
Bruce Bowker
Perhaps one of the new components is bad out of the box?
My car also has 4 Strombergs. My kit came from SNG Barratt and installed in no time at all, no adaptions etc with no adjustments afterward.
E Series III had carbs to 1974. Seems the XJ12 should be about the same engine as mine.
jessebogan
So, the XJS was like a master tech exam. First, the accumulator ball was bad, pump ran every time you hit the pedal, and light was on. Then the ECU had 3 codes, one of which was a failed self test. Installed a used unit from stock.... Then only 1 code, for RT ft wheel speed sensor. Had one in a parts car. Jacked up the junker, and pulled it off. In the dark... Changed that, road test to clear codes... Light still on, now a code for RT rr sensor. (ECU will only show one code per "system", fix one to advance to the next) Someone had cut and spliced that one up inside the body. Had one on the shelf. Finally light off, and correct operation of system.
I don't believe in throwing parts, each was a documentable failure....I am glad I part out these cars somedays. Customer picked it up, and was delighted, first time in years that the system worked. It is just never simple with these cars...
Dropped the engine in the DS 420 today, now I have to make it run. Hasen't in 15 years. Beautiful car tho... (for a DS 420)
I am outta here!!
Platinum
We kept similar "collections" for the same reason. "Known good" parts can be a gold mine.
THAT'S the stuff to try your patience most times. Some jack-leg hack gets into the thing a decade or two before you and YOU get to suss out what's been made to <span style="font-style: italic">half</span> work. UN-fixing the sins of prior hack jobs can be the biggest time waster.
If we're ever able to sit together an' swap war stories, remind me to relate the tale of the Corinche intermittent wiper control box. :wink:
Uh oh.....Corniche = BIG $$$$$$$$$$$$$$$$ no matter HOW you slice it! That and :wall: :wall: :wall:
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
D Series III E-Type Overider Rubber Installation Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
M Looking for a E Type Series III Bell Housing Jaguar 1
S Bouncing Tach on Series III E-Type Jaguar 4
G Series III E-Type problem to look out for Jaguar 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
toysrrus Series III Rdstr. Top Bows [Grey] & Vinyl [Blk] Top For Sale. Jaguar 4
D XJ6 series III front end rattle Jaguar 5
D Series III side marker to blinker conversion Jaguar 2
M 87 Series III XJ6 Rough Running Jaguar 16
M 87 Series III XJ6 won't Start Jaguar 16
M Series III XJ-6 4.2 Liter Cylinder Head removal Jaguar 7
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
Sprocket Series III factory service manuals - $50 Jaguar 0
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
bmurphy7369 Late Series III motor/FI into a Late Series II XJ? Jaguar 5
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
P Correct steering wheel for Series III Sunbeam (Rootes) 3
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
