Series III E-Type Overider Rubber Installation
DaveatMoon
I have a car in the shop which the customer brought in with reproduction overriders. The rubber faces of the overriders are not attached, and have simple flat blades sticking out of them that pass through slots in the chrome piece. They are not drilled for nuts, and appear to be much too robust to bend without tearing the rubber.
Has anyone run into these before? Is there a clip or something missing that holds the rubbers in place on the overrider? Any help would be appreciated!
HEALEYJAG
The series 3 had 3 different types or overriders. From your description I could not tell which one u have.. A picture would be very helpfull..It sounds like you have the second type which means the sides fit into the chrome ovals..they are suposed to be tight.. you cannot tear this rubber.. I would recomend u get new ones though...
Pete
DaveatMoon
Sorry, I should have mentioned that these are the first generation overriders for a 1971. They are chrome bodies with a small rubber face that attaches to the front of the body. In the chrome body there's a square hole for the carriage bolt that attaches the unit to the bumper, and 2 slots 1/2" wide 3" apart that allow the metal blades embedded in the rubber to pass through. I don't have the ability here to post a photo.
Thanks for all the help you can provide.
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
J Question about Series III XJ6 Motor in E Type? Jaguar 2
Bruce Bowker Series III E Type Jaguar 9
M Looking for a E Type Series III Bell Housing Jaguar 1
S Bouncing Tach on Series III E-Type Jaguar 4
G Series III E-Type problem to look out for Jaguar 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
toysrrus Series III Rdstr. Top Bows [Grey] & Vinyl [Blk] Top For Sale. Jaguar 4
D XJ6 series III front end rattle Jaguar 5
D Series III side marker to blinker conversion Jaguar 2
M 87 Series III XJ6 Rough Running Jaguar 16
M 87 Series III XJ6 won't Start Jaguar 16
M Series III XJ-6 4.2 Liter Cylinder Head removal Jaguar 7
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
Sprocket Series III factory service manuals - $50 Jaguar 0
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
bmurphy7369 Late Series III motor/FI into a Late Series II XJ? Jaguar 5
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
S Easiest way to disconnect Tach on XKE Series III Jaguar 4
P Correct steering wheel for Series III Sunbeam (Rootes) 3
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
