Alternator or Battery Problem on 87 XJ6 Series III
Michael J.
This one has me totally baffled.
I started noticing that the voltmeter, "Battery Indicator" would stay pegged at low end for several minutes after starting, gradually raising to indicate never more than about 12 volts.
Sounds like classic battery or alternator right?
Brought it to local part store. The put a tester on the system and determined alternator was bad. Replaced alternator.
Problem persisted. Thought it might be the guage. Now getting hard starting problems as if the battery is dead. Hydrometer has one cell lower than the others, but still in good range.
Sometimes starts smooth other times starter relay clicks.
Wiring diagram depicts four wires connecting to the alternator.
There are only two. This car has the Motorola Alternator rather than the Lucas.
What am I missing here?
Is this an ignition switch problem? That does not seem correct.
Suggestions anyone?
Clean battery terminals, have battery checked (free) on the machine at Advance/Oreiley/Autozone, Check the ground terminals for tight clean connections, check the battery cables for internal corrosion. Check to make sure there isn't something draining the battery overnight - interior lights, underhood/boot light, radio, etc.
John S Farrington
Go to your alternator connectors. The larger of the two wires should be battery 12 volts all of the time. The smaller of the two wires is the exciter voltage that should be 12 volts with the ignition switch on. If you had no or intermittant excitation voltage, the charging system could act as you describe. Also make sure that your alternator drive belt is tight. Jack
Exotexs
Re: Alternator or Battery Problem on 87 XJ6 Series
1) I have been told that when you replace the alternator, you also replace the battery, because the bad (old) alternator compromised the old battery, and because the old battery will then compromise the new alternator. Whether that is true or a Sales Gimmick, I don't know, what I do know is that the last time I replaced the alternator, I also replaced the battery and well, I have not been dissapointed.
2) in my '84 XJ-6, the voltage gauge is somewhat slow to reach up to the 12-13 volts mark as well, so I don't think it's the Gauge itself. As my mechanic friend says, it works or it doesn't...
3) you might service the two "POSTS" located at the firewall, (bulkhead), sticking out into the engine compartment from the interior, one on the left side, one on the right of the engine, covered by rubber boots. There are many wire bundles connected to these two posts by ring terminals. Undo each nut on each post after pulling back the rubber boot, (very carefully, the rubber is usually brittle), and with a Brass wire brush, pull and clean all ring terminals and then the post threads until shiny. this helped revive the electrics in my XJ, making everything brighter and livelier.
4) after you shutdown the ignition, turn all switches off and close all doors, check the rear lights to see if the Brake lamps stay on, you could have a stuck brake light switch. If it is bad, these switches can be repaired, so open it and try to fix it. Also check the marker lamps mounted on each door panel, if a door switch is stuck open or is shorted, the bulb will stay on, draining the battery overnight.
M
Michael J.
I ended up replacing the ignition switch after some other wierd behavior surfaced with the switch.
With the switch replaced things behaved as Jack Farrington described
Things are now back to normal.
Thanks everyone for the suggestions.
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
Mark Jones Battery/alternator question Triumph 5
gsalt57tr3 Wedge TR7 alternator not charging the battery Triumph 2
Cain Battery or Alternator Triumph 9
John_Mc Battery, alternator, or ? Triumph 15
T TR6 Alternator wiring Triumph 6
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
