series 2 e-type bonnet
HEALEYJAG
I have noticed two different mouths on various series 2's. One where it is very oval and the other where the corners are more square. I have looked at many pics and can't seem to find a correlation. I am finishing off my bonnet that I bought used and do not want to do this twice.
Thank you for your input:
Pete
Pete,
Best I know, 1968 was the last year of the oval mouth and running lights above the bumpers. In 69 the mouth was opened up, parking lights enlarged and put underneath the bumpers. There has always been discussion about the 68 car whether it is Series 1.5 or series 2. You can swap bonnets on the SI and SII cars, they mount the same. Dont'e think you can put the(72on) SIII bonnets on earlier cars without some mod.s, SIII looked like the SII but had flared fender wells, the mouth was changed some as well. Underneath bonnet is different. Hope his helps
Marv
HEALEYJAG
HEALEYJAG
Thanks Marv..but what I was looking for is the difference in the mouths of SERIES 2 bonnets. Some are more oval and others have more squared corners...
\Pete
sbs
I've never heard of such a thing.
Can you provide examples?
Platinum
I'm curious as well. Could the "more squared" ones observed have suffered impact and been "reshaped" by unknowing body repair?
Grantura_MKI
Marvin provided you with the correct answer. If you search the panel suppliers, there is only one bonnet centre section and lower panel offered for a series 2.
I have restored several and have built up complete bonnets from different donors and have never had a problem. Do you have the pictures in hand to show what you are talking about?
Cheers,
David.
HEALEYJAG
HEALEYJAG
If you go to XKEdata.com and scroll through the series two cars you will see distinctively different bonnett openings on the series 2 cars. I have owned all the series over the years, and only recently when replacing mine on a seres 2 have I noticed the difference.
If I were more computor savvy I would download the two openings.
I do not think it is due to body work doc ...mine is "more squared corners and has no bodywork..
Feel the early 69 are different than later 70??
Pete
Platinum
I honestly never noticed... and embarrassed as a result. All the Jags I've worked on over th' years. :shocked:
S-III's are the exception, obviously.
...and I think they're butt-ugly by comparison, too. :wink:
Grantura_MKI
Do not know what to say. I have a 1969 in the shop at the monent, and it does not have as you say "square sides". Finished a 1970 a year and a half ago, and the bonnet was the same as the 69. Bloke was the original owner of the vehicle and it had never suffered any damage.
I understand your computer delema, as I have the same disadvantage.
Martin Robey lists only one lower panel for all series 2 vehicles.
Strange one!
Cheers,
David.
I'm glad there are others who are scratching the heads as well. I have owned and restored several S1 & S2 cars, never noticed any differences as mentioned. Will be looking!
Marv
Grantura_MKI
Hi Marvin,
Just curious. The lower panel is quite a complex piece of metal work. The inner ducting fits into the sides of the mouth. On your bonnet, are the inner ducts shaped the same ie. 'square side', or do they have a different radius?
Cheers,
David.
David,
I remember the S1 inner ducting as being shaped around the oval ends. Would have to look at the S2 to tell you correctly. The bonnets look scarey to disassemble but actually go back together pretty easy. I used epoxy to hold the brace panels on.
Marv
Grantura_MKI
Hi Marvin,
I do not enjoy the disassembly process as much as the reassembly. I use a 3M epoxy sealer to fit the inner panels as well. I let them stand for 24+ hours before disturbing them. Sounds like you are doing a top job of it. Would still be curious about the front ducting.
Cheers,
David.
Jagboy69
May I offer a simple solution? Perhaps he saw one fitted with amco bars and is comparing it to cars without? There should only be ONE style of bonnet opening for the series 2 cars. The series 1.5 suffered some effects to the placement of the headlights fore and aft as well as parking light arrangement and bumpers ect.
bj7
I have restored 3 Series 2 E types and currently have a late 1969 model. The cars I have seen or restored have always had the same shape opening. Fron my experience with computer images, they sometimes distort the image with reference to height and width. Maybe if you cant download the images you maybe able to list the car numbers on the database in which you have noticed a difference.
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
