E-Type Series 3 V12 distributor
Rick60
Hi all,
a friend of mine is having serious ignition problems with his car.
I'm not sure whether the dizzy in his car is the original one. Can anybody tell me what kind of distributor was installed originally in an E-Type Series 3 V12?
What are the main problems with the ignition on that kind of car and how can they be cured best. What are the best general improvements on the ignition on an V12 E-Type?
Thanks for all your help.
Tullamore
My car has been converted to electronic ignition and recently wasn't running so great. After I changed my rotor, cap, and plugs it was an amazing difference.
The original distributor is a Lucas OPUS model when I changed the cap this week I used a new Lucas cap I got from Moss.
Platinum
Those units are NOTORIOUS for having the advance mechanism corrode and lock up. Best "first step" is to find #1 TDC (firing), mark it and pull that dizzy out/apart. Go thru it thoroughly to insure proper function before you get bogged down in trying to "troubleshoot" the rest of it. Then a conversion to a Crane X-whatever trigger and control box.
This may sound Draconian but it will get you rolling and reliable in short order than goin' thru all the agro you would have trying to "patch" what's there if original.
...that's my story and I'm stickin' to it.
jessebogan
I find that "Kroil" works a treat for freeing off frozen mechanical advance units in the 12 cylinder distributors.I have tried everything, including making a tool to help rotate the advance mechanism, but Kroil works the best.
If you want the Etype to look original, XKs in California sell updated innards to the OPUS box. I have not tried one yet, but I like the idea. I wish they had one to fit later XJ12s, .... The other alternative would be to change the whole thing out for a later XJS lucas unit. The distributor is an exact interchange, and believe it or not, the ignition amp and pick up have proven really reliable.
ADIPaul
Hi Eric,
I've probably come in on this thread a bit too late, but for the benefit of anyone searching the archives, you might want to take a look at our solution to the OPUS ignition problem. (web site in signature)
Regards,
Paul.
JeffS
Nice solution to a common problem! Too bad the exchange rate is so horrible for us! There's a Pertronix kit available for about 1/3 that price that allows you to completely bypass the amplifier. Its part #LU-1122, good for all V12s with opus through '81. '82 and on cars are more reliable with the DM distributor.
One of the common issues with the V12 is that once you disassemble the advance the plastic retaining clip gets broken and the advance no longer stays together. By having the tip of the shaft machined for a screw like the older distributors, you can get the excess end play out of your advance assembly too. Its a cheap 2-for-1 repair! The igniton curve isn't too bad in most of the Opus V12s, but it can be altered at the same time by a reputable distribtor guy for a fair improvement in throttle response as well.
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
