Series 2 E-Type won't rev.
dlamb43
Member
Have a '70 Series 2 E-Type which I am still sorting. It runs great..correct timing etc.and pulls strongly up to about 3500 revs.then starts to feel tight and "surge"..at 4000 revs it runs out of everything as though it had a governor fitted (it hasn't!!). Anyone any ideas where to start?? Bouncing points? Wonky Distributor shaft? Bad cap. Or are we talking some serious engine rebuilding? Thanks for any info. I'm a first-time E-Type owner but had a 140 in the sixties! Cheers. David /ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif dlamb43@adelphia.net
Repro
I am no expert, but it could be a fuel flow problem. Fuel pump or blockage. Are the floats at the correct level in the float chambers?
If the surging is accompanied by a miss ( i.e. one cylinder not firing) it could be a high tention lead breaking down.
Good luck, Ross.
Keoke
You might try pulling the air filter off and see what happens then.--FWIW___Keoke
dlamb43
Member
Thanks fellas for the input. Will check compression as soon as I get a chance...but it's DRIVING weather...grab it while you can up here! Carbs were rebuilt just before I bought the car, but that probably means zilch! High tension lead breaking down ?? Now that's an attractive possibility so will replace it or all.(But only at 35000 plus????)Air filter all clear and doesn't seem to be running lean. Thanks all. Will keep you posted on progress. Cheers. David
AltaKnight
Replace that 10cent condenser next to the points and see if that fixes it.
Your description exactly matches a problem I had on my mini about 30 years ago.
John S Farrington
If you are still running points, I would recommend that you switch to a solid state ignition. I use the XJ6 ignition in my E type but a Pertronic is also very good. This upgrade and replacement of the ignition wire set, spark plugs and distributor cap should geet rid of your problem.
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
B Series 1 E-Type fuel pump question Jaguar 2
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
