Series 1 E-Type fuel pump question
Bob60
Member
I have a series 1 E-Type coupe with the submerged fuel pump. I'd like to have some sort of back-up system. Does anyone know if an electric pump such as one of the small Facet pumps will pull fuel thru the existing submerged pump if the submerged pump would die? Alternatively - does anyone have a later (4.2 and on) fuel pick-up with cover plate they want to get rid of?
Thanks
Bob
Deleted member 8987
Submerged types are aftermarket, if I recall. Most are rotary vane-type, which makes it very difficult to draw through when stopped (as in, failed). If it was mine, I'd pull the pump and plate and add another pickup tube, feed it to another pump with a shutoff valve to switch between and a switch to select either.
Early E types had the fuel pump inside the tank. I have an old one laying around somewhere, pretty sure you can use the existing one with external pump. If nothing else, put one on and try it as it is, don't turn the ignition. Seems like I did that a few years ago and worked fine.
Marv
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M E-type series 1 plastic dash vents Jaguar 1
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
Q Series 1 E Type Clutch Jaguar 2
D Series III E-Type Overider Rubber Installation Jaguar 2
H Joan Baez flat floor series I e-type roadster: what did the authorities dump it for? Jaguar 0
Simmo Series 3 E Type Brake Bleeding Jaguar 2
J Question about Series III XJ6 Motor in E Type? Jaguar 2
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
weewillie Red series 1 or 2 E type Spotted 0
glemon Series 1.5-2 E type, flat towed Spotted 0
glemon Series I E type project Jaguar 17
HEALEYJAG series 2 E-type eyebrow chrome "clips" Jaguar 0
S E-Type 4.2 Series II Performance Exhaust Jaguar 1
jjbunn E-type Series 2 PRNDL shifter ID plate and parts Jaguar 0
rovernut 1970 series 2 e type serial number location Jaguar 6
T Series 2 E-Type Diff Oil Leak... Jaguar 5
Steve Red Series 1&1/2 E-Type.... Spotted 0
Bruce Bowker Series III E Type Jaguar 9
Basil Drool Series I E-Type Jaguar 10
HEALEYJAG series 2 e-type bonnet Jaguar 14
Jim_Newman 4.2 series 1 e-type throwing coolant Jaguar 6
HEALEYJAG e-type series two oil filter Jaguar 6
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
M Looking for a E Type Series III Bell Housing Jaguar 1
S Performance Exhaust for E-Type 4.2 Series II Jaguar 3
C Series II E Type Clock Battery Jaguar 2
Rick60 E-Type Series 3 V12 distributor Jaguar 5
S E-Type Series II OTS Exhaust Jaguar 0
S E-Type Series II OTS Sound System Upgrade Jaguar 0
D Series 2 E-Type won't rev. Jaguar 6
B 69 Series II E-type Hardtop window Jaguar 0
S Bouncing Tach on Series III E-Type Jaguar 4
R Radiator -Series 1 E-Type Jaguar 0
L E-Type Series II vacuum connections Jaguar 0
G Series III E-Type problem to look out for Jaguar 1
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
