TR2/3/3A layout for lap type seat belt
deuce
Hello all.... I am going to install lap belts in my 1960 Tr3a. Two questions.. I got belts from Moss (short). Are these correct ? The originals were longer. Where should the buckles locate when in use?
OK, three questions. Can anyone give me the anchor locations for the hook type attachments? That is what was original. TIA
charleyf
What was original--Interesting question! Have you found any large holes in the body where the previous anchors were located? Likely not or you would not be asking this question. My answer is that I am not sure when Triumph or the dealers started putting seat belts in, but my 1960/1961 TR3A did not have any when I got it in 1962 or 1963.
I just finished a restoration of a 1959 TR3A which was preceded by 2 TR4 restorations. The late 1962 TR4s did come with seat belts. So on the TR3, I tried to duplicate where the anchor points were on the TR4.
The anchor points should not change between the bolt or hook type.
I have included 3 pics of the anchor locations that I determined to be best. This is on a 1959 where the rear shelf may be different than your car. So the center anchor would be more forward. The third pic is the view inside the rear wheel well.
I believe the buckle should be to the center and the adjustment should locate the buckle at the center of the passenger. Check your new set to see if they are long enough before you try to install them.
You said you had an original set of belts. Maybe so and maybe no.
Charley
ckeithjordan
As the early TRs did not come equipped with seatbelts, Standard Triumph issued instructions for retro fitting. See attached.
  • ST Seat Belt Fitment_.pdf
  • tr3belts.pdf
CJD
Keith, I am impressed! I have seen the template for 2-point mounting many times, but I did not know about the factory bulletin for 3-point.
Deuce, something to think about is that many TR accidents envolve a roll over, since the track of these cars is so narrow. I put seat belts in my TR3A, but did not in my TR2. My fear is that in a roll over without a roll bar, your head is vulnerable. So, while seat belts will help in non-roll over accidents, I think they will be worse in a roll over. Plus, it would be a bonus to be able to move to the side of the non-telescoping steering column in a forward collision to prevent being shish kabobed. Just food for thought.
Also...with the factory belts, they tend to fall out of the car and get slammed when the door is shut?!?
JHaydon
Yes, yes they do. And they make a heck of a racket when the door opens and the buckle hits the sill plate on the way down.
PO installed plain lap belts in my 59. I have a set of retracting belts from Moss waiting to replace them.
deuce
Thank you all for the input, layout diagrams, etc. The way I read it, Ohio requires all vehicles to have front seats to have belts... so now I have them. Almost ready for the maiden voyage.. after 8 years restoring this beast.. 30 years since it has been on the road. Waiting for things to dry out here with snow, rain, gloomy weather for weeks it seems. So, thanks again all.
George
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
RAC68 Harness Layout and attachment to a BJ7 Austin Healey 5
A TR2/3/3A TR-3A gauge layout Triumph 6
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
letemglow Brake line layout with dual master cylinder MG 6
K TR2/3/3A Picture of TR3 Dash Gauge Layout Triumph 2
BoneIdle MGB-GT 1974 GT fuse box layout MG 8
Steve P. Bugeye electrical layout question Spridgets 7
19_again Shift pattern layout Triumph 14
CCURTISS TR2/3/3A TR3 Knob Layout Triumph 8
rlandrum Engine Bay Layout Question Triumph 16
ronzet Dash Layout Austin Healey 6
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
AngliaGT MGB A B Fell into my Lap.... MG 15
R BJ8 in India - on the F1 Parade Lap Austin Healey 0
MadMarx [video] Zandvoort - fast qualy lap Triumph 11
D Riccardo Patrese's wife on her first "hot lap" Racing 15
S Video of my fast "parade lap" in Elan S1 Lotus 4
Popeye Welding: Butt- or Lap? Restoration & Tools 12
B Adding lap belts Spridgets 14
M Sebring 2007 GT2 last lap Racing 1
G Free old pair of Britax seat lap belts Triumph 1
A Flanging tool for lap welds Restoration & Tools 5
H MK2 lover, but... what about an E type? Jaguar 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
