MGB-GT 1974 GT fuse box layout
BoneIdle
Greetings all!
Work on the GT was suspended for a while due to a death in the family, but now I'm back at it.
I've had a problem with the battery draining totally to nothing for some time now. I had assumed that the battery had finally exceeded its service life, so I replaced it.
Although the old battery did test bad, the problem has recurred with a brand new battery.
Finally, I got off my lazy posterior and hooked up a test light between the positive battery post and the cable. I ensured that the key wasn't in the ignition and observed that the little test light was glowing.
I began pulling fuses, one at a time, and the light finally went out when I pulled the bottom fuse in the fuse box.
I can't find the cover for the fuse box, and I'm not sure that it would have this information on it, so what does that particular fuse control?
I tried a search on here, but I got bogged down pretty quickly, so I figured I'd just ask.
I do have a very good manual somewhere, but I'm still trying to locate it. When we moved from Iowa, the movers packed things too well.
Thanks. It's good to be back.
Garry
Platinum
Hi Garry. What are the colors of the wires goin' thru the fuse in question?
BoneIdle
BoneIdle
Looks like brown and gray ( or tan). I'll have to get a better light source going to be sure.
BoneIdle
BoneIdle
Well, it's the brown wire that's causing the problem. I pulled that one from its connection and the light went out.That narrows it down somewhat.
BoneIdle
BoneIdle
Gee. It looks like I'm back to the original suspect: the hazard flasher and/or hazard flasher switch. Now if I could only figure out where the flasher is. It's definitely not next to the turn signal flasher.
JPSmit
Just looking at this diagram
https://www.advanceautowire.com/mgb.pdf
looks like there should be three brown wires
1.one to seatbelt buzzer etc.
2.one to starter relay
3. one to ignition, headlights and hazard relay.
If you have isolated it to the 3. above, and likely the hazard flasher. If there is any comparison to my Midget, one flasher is by the hazard switch behind the dash and the other is attached to the firewall above the glovebox.
FWIW any cheap autozone/harbor freight flasher will work
BoneIdle
BoneIdle
"Wanna see something really scary?"
I just pulled the console. The flasher may or may not be good, but for future reference:eek:n a 1974 MGB GT, the flasher is mounted behind the console on the driver's side. It's pretty low down - just above the transmission hump.
The scary part was the stereo. It was ( and still may be) a very nice Kenwood, but the way it was connected...
Anyway, I snipped the black wire ( stereo side) and the test light went out. I haven't had a chance to trace down the wire, but that stereo is coming out for the time being.
More later, and thanks for the replies!
Garry
Platinum
I was at a client's place when I replied, just got back to th' hovel.
That brown set of wires will be hot at the fusebox, they're supply side. You likely found your draw tho.
BoneIdle
BoneIdle
Yeah, Doc. It looks like it was a combination of the radio and the flasher. After snipping the wire, I plugged the flasher back in and the light came on.OTOH, it could be the flasher switch is permanently on. I'll know more once I completely disconnect everything and put a meter on the switch to check for continuity.
wkilleffer MGB MGB 4-way fuse box question- 1974 MGB MG 8
P TR6 Horn issue 1974 TR6 Triumph 5
D Trying to get back working on the 1974 Midget Spridgets 12
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
VeeCee MGB 1974 MGB Roof Installation MG 0
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
J 1974 Jensen Other British Cars 22
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
P MGB 1974 MGB front spring length. MG 0
H TR6 1974 tr6 allison xr700 Triumph 12
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
A MGB MGB 1974 windscreen centre rod replacement MG 5
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
R SOLD!! 1974 Jensen Healey Other British Classifieds 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
krswen For Sale 1974 Panther J72 Other British Classifieds 4
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
A 1974 2500M Spring Rates TVR 6
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
B 1974 Midget Spridgets 6
jmayzer For Sale 1974 MG Midget Mk III [Maryland, USA] Spridgets Classified 1
J MGB 1974 1/2 MGB gasoline type MG 5
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
wkilleffer MGB 1974 MGB convertible top anchor bar size MG 4
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
F MGB Correct steering wheel - 1974 MG 2
AngliaGT 1974 Midget - It's ALIVE!!! Spridgets 7
AngliaGT Early [11/73] 1974 Radiator Removal - Spridgets 4
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
T 1974 jensen healey Other British Cars 17
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
S TR6 1974 TR-6 project....I'm holding my breath and praying Triumph 13
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
D Found a 1974 Jensen Healey Spotted 3
wkilleffer T-Series Clutch pipe installation- 1974 MGB MG 2
