Cut-away B series engine...
Boink
Bronze
One of the coolest things at the Portland ABFM was the wonderful cut-away B-series engine made by Keith Ansell and Ken Synder. Keith has been around forever in the Portland area and is one of the old-time go-to people here. This engine had to take a LONG while to make and it had a crank on it to turn it. Every little spot had detail that revealed all aspects of the engine. It was amazing...
Each piston was different, with different compression types. In the second photo I shot you can see a hardened valve seat in place (and the guides).
Boink
Boink
Bronze
In these last two shots, you can see the other side of the engine (with tappets) with the cam (and oil pump drive). The last shot gives credit where credit is due...
aeronca65t
I <span style="text-decoration: underline">love</span> stuff like that. Thanks!
Years ago I built an aluminum GEO Tracker engine cutaway like that for my students, but we tossed it when our program moved away from automotive to more mechanical engineering.
It reminds me of the cutaway MGB GT that BMC used to use in various car shows.
Mickey Richaud
That IS great! Would love to see it "in person".
Can it be put in motion? THAT would be fantastic!
Thanks for posting it!
Mickey
Edit: Oops - just went back and read the part about the crank.
Flash_Harry
A first-rate job by Keith and Ken. First one I saw like that was in the "Industrial Arts" office of the high school, about 1954 - 55. Pretty sure it was a 6-cylinder Hudson engine, cut away like this MG engine. Might even have had an electric motor to turn it - can't remember that part, but it helped to turn me to 'the oily side'.
Boink
Boink
Bronze
I really like how they mixed and matched different pistons, tappets and other things found on these engines. The one thing Keith told me they had to change was to use wimpy valve springs because it was too hard to crank otherwise.
swift6
There is another half of that MGB-GT. Last time I saw it, it was across the hall from that half at the BMIHT museum in Gaydon. I was told that they were made for an Earl's Court show and that the display stand would rotate, as the stand rotated the split MGB-GT would start pushed togehter and then split apart to show all the innards. Supposedly when it was closed up you couldn't see the split from the edge of the stand, you had to get right up next to it to even see the line.
CJD TR2/3/3A Cut away TR3 Triumph 6
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Rut Cut down windshield Spridgets 22
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
D cut-off switch Austin Healey 20
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
J Windshield question pt.2: Why not cut the frame? Spridgets 9
Boink Battery cut-off switch options... or??? Spridgets 10
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
D battery cut off switch Austin Healey 29
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
Tinkerman Battery cut-off switch installation Triumph 22
AUSMHLY fuel cut off Austin Healey 23
vping T-Series Adding a battery cut off switch. MG 16
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Ouagabambou Cut, torn steering inner tube [+ photograph] Austin Healey 22
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
B T-Series cut off switch in MGB? MG 7
T What year cut-over to the 1500? Spridgets 13
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
J TR6 Inertia cut out [off] switch TR6 Triumph 9
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
tahoe healey fuel pump cut off switch post Austin Healey 21
T Cut/Splice Spark Plug Wires?? Triumph 13
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
G Fuel cut-off valve MG 5
A Battery cut off switch Austin Healey 15
P Jag XJ8 starts but then dies right away. Jaguar 4
