Cut, torn steering inner tube [+ photograph]
Ouagabambou
Bonjour,
This is my first post on this captivating forum. Unfortunately, this time, the question is mine.
My A-H is a MKI, beautifully reconstructed in 2001 from a Californian import, not by me but by M. BOCHE in the centre of France.
Poetry in motion...until....
...the trafficator and the horn button suddenly became useless. Same with the wiper (same fuse). I have just understood why : the top end of the lower part of the inner tube messed up either with the wiring harness or with the upper part of the tube. It cut itself at the level of the lower end of the groove (10 cm approx. from the end) and beheaded the harness (a tradition here) at the same level.
So I end up with an inner tube and a harness to be replaced.
Questions :
- did this happen to one of you already, and what could have caused it ?
- can I replace both parts without taking too many bits out of the way, namely the steering box or the radiator ?
Merci beaucoup.
Olivier
Olivier -
To be specific, this tube is called the "stator tube." Yes, it can actually be quite easily removed by pulling it up into the cockpit.
First remove the brass olive nut & olive from the front of the stator tube (the little part sticking out the front of the steering box). Be careful as any oil in the box will leak out now, put something under the front of the steering box to catch the oil.
Then ... probably the easiest trick would be to thread a piece of stiff wire through the stator tube and tie a big enough knot on the end so that when you pull the wire up into the cock pit, it pulls the tube with it. I hope you understand what I mean.
Putting the new stator tube in can be tricky, but I'm sure once you know how it is put all together, you can figure something out.
Damaged stator tubes aren't all that common, but they can happen when the metal turn signal canceling tongue on the trafficator is bent too close to the metal plate in the trafficator, dragging on it as you turn the wheel. You need to make sure there's enough clearance so that it does not grind against this plate.
Bon Chance!
Thank you very much, Alan.
I have understood your idea for taking out what is left of the stator tube.
The second good news is that I can repair that just with taking the grille away.
Many thanks again.
Olivier
Exactly !
This is what we call here "un coupé" or "un break" !
Hi Alan,
I've never tried to put an adjustable column stator tube back in from the cockpit. Seems like threading the tube into the steering box when the stator tube is 10" shorter than the column would be really difficult. I'd probably replace the tube from the front.
GregW said:
Hi Alan,
:iagree:
Me Thinks you are about right.However, if a dowel small enough to make a friction fit in the lower section of the stator tube extending its kength could be made or located, that might let you do it.----Keoke-
Thank you all.
Could the upper section of the stator tube be this dowel?
I wonder in which part the end of the lower section of the stator tube has to be fitted... Is there a thread ? requires a big torque ?
My diagrammes are not very talkative when it comes to this specific area...
Look :
Ouagabambou said:
Thank you all.
No I do not think so it probably does not have adequate grip and you may end up with the lower half floating around inside the steering shaft.
No it simply slides through that small hole in the fitting at the end of the steering box that allows attachment of the stater tube securing Olive and Nut.
:savewave:
Make certain that the black ring shown fitted to the upper part of the stater tube is there. I think if it were missing you would see the type failure you experienced.
Look :
Regards Keoke
Thank you very much, all and Keoke. I order the parts and do it.
Olivier
GregW said:
Hi Alan,
yeah, you are mostly right.... but with an appropriately sized wooden dowel you could probably get it done this way.
Please describe what an "olive nut & olive" are. A picture would help if available. New term for me.
Thank you, Bob.
With a piece of wire, I shall try to catch what is left of the stator tube from the cockpit, for sure. But I feel that installing the new harness and connecting it and securing the olive and nut will be more comfortable from the front. Removing the grill looks easy, no ?
Olivier
For Darwin,
The harness goes down through 30,31,34,35. When you tighten 35 (the nut), 34 (the olive) acts like a ring clamp around the harness and keeps it prisonner.
Olivier, ze specialist of olives.
Thanks, explains it perfectly. Always learn something new here at BCF. What an asset to us all.
Olivier,
I just took a look at my BJ8 (essentially the same grill as on your car). It doesn't appear that removing the grill will allow the stator tube to be removed from the front--you'd have to remove the shroud. I believe the entire steering column can be removed through the grill opening, but you'd have to release the steering column from its clamps on the chassis and the dash (fascia). Maybe you'll have to do that, but I would exhaust all means to get the tube out from inside the cockpit first. You should be able to push the tube out from the front with a screwdriver or dowel far enough to get a grip on it with some long needle-nosed pliers (see: https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39538 ).
I've pulled my stator tube this way (but mine wasn't mangled like yours). Releasing the steering column should be a last resort. BTW, the stator tube on adjustable columns is a known problem--the slot which engages the "nipple" on the upper (sliding) part is cut with sharp, square corners and stress cracks develop at these corners (the slot should at least have radiused corners). That's why I had to replace my stator tube.
Bob
Bob,
No, no, I do not want to move the steering column. Push from the front, pull from the cockpit until I can extract it from the top end of the column.
Next week end...
Thank you.
Olivier
Hi Olivier,
If you go with the dowel idea that Keoke came up with, you might want to consider using a pencil sharpener on the tip of the dowel. That might make it easier to get it through the hole at the front of the steering box. You might also want to mark the stator tube's front in line with the notch. That way, when you're tightening the olive nut, you can get things lined up easier.
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Rut Cut down windshield Spridgets 22
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
D cut-off switch Austin Healey 20
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
CJD TR2/3/3A Cut away TR3 Triumph 6
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
Boink Cut-away B series engine... MG 6
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
J Windshield question pt.2: Why not cut the frame? Spridgets 9
Boink Battery cut-off switch options... or??? Spridgets 10
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
D battery cut off switch Austin Healey 29
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
Tinkerman Battery cut-off switch installation Triumph 22
AUSMHLY fuel cut off Austin Healey 23
vping T-Series Adding a battery cut off switch. MG 16
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
B T-Series cut off switch in MGB? MG 7
T What year cut-over to the 1500? Spridgets 13
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
J TR6 Inertia cut out [off] switch TR6 Triumph 9
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
tahoe healey fuel pump cut off switch post Austin Healey 21
T Cut/Splice Spark Plug Wires?? Triumph 13
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
G Fuel cut-off valve MG 5
A Battery cut off switch Austin Healey 15
RAC68 Torn Frame…and the Saga goes on Austin Healey 20
