TR2/3/3A Cut away TR3
CJD
Went to look at some Craig's list parts yesterday and met a very interesting gearhead in Arlington, TX. He has a complete cut-away chasis for a TR3. By that, I mean he took the time to cut a hole in every part on the chasis...engine, gearbox, brakes, steering. And every subassembly too...like coil, distrib, oil filter...
Very interesting and very impressive that he took that amount of time to do it. He says he used to take it to the contests, and half the people would complain he took a car that wasn't ready to show yet. Guess not!
I would have taken pictures, but it was sleeting and I didn't want him to go to the trouble to uncover it in the cold. I may have to go back, though!
Interesting!
Did you recruit him for the forum?
So what do you mean John? It looks like one of those clear plastic models of the human body. We need to trade Craig’s lists. We hardly ever have tr3 parts way up north of you.
John-
Can't remember his name, but I met him as well - interesting guy. It wasn't a hatchet job either - very nice and clean. Hated to see his work under a tarp in the backyard, it would be a good club thing to have if someone could store it and clean it up for a show.
Randy
It truly needs to go to a Triumph club somewhere. Like Randy says, it was a real act of love and done just like you see in museums...but is slowly wasting away in the back corner of his yard. Just a weekend with a brush and some paint would make a real display piece. The only part without a display window is the differential...but everything else has an opening, and it still turns and operates.
If anyone knows of a club/museum or such, I'd be happy to do the footwork here in Fort Worth...
I did this a few years ago with one small part. I called it 'The Visible Distributor':
Interesting to watch in action -- I can imagine what the car you describe would reveal.
sp53 said:
...looks like one of those clear plastic models of the human body...
That was my inspiration - The Visible Man, The Visible Woman and, of course, the somewhat disturbing:
Boink Cut-away B series engine... MG 6
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Rut Cut down windshield Spridgets 22
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
D cut-off switch Austin Healey 20
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
J Windshield question pt.2: Why not cut the frame? Spridgets 9
Boink Battery cut-off switch options... or??? Spridgets 10
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
D battery cut off switch Austin Healey 29
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
Tinkerman Battery cut-off switch installation Triumph 22
AUSMHLY fuel cut off Austin Healey 23
vping T-Series Adding a battery cut off switch. MG 16
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Ouagabambou Cut, torn steering inner tube [+ photograph] Austin Healey 22
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
B T-Series cut off switch in MGB? MG 7
T What year cut-over to the 1500? Spridgets 13
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
J TR6 Inertia cut out [off] switch TR6 Triumph 9
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
tahoe healey fuel pump cut off switch post Austin Healey 21
T Cut/Splice Spark Plug Wires?? Triumph 13
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
G Fuel cut-off valve MG 5
A Battery cut off switch Austin Healey 15
P Jag XJ8 starts but then dies right away. Jaguar 4
