Intermittent engine cut out 1989 v12 xjs
vfr2009
Dear Friends
My 1989 xjs v12 started to suffer intermitent engine cut outs, it started first after a long run 100 miles, the car was parked for three hours, 10 minutes after restart, as it reached op temp it died, I waited 20 minutes it started and ran all day. the next morning it ran for 10 minutes then died. The intervals got shorter until it would die on every trip, wait 20 mintes it starts again then dies when it reaches operating temp once more. My jag specialist diagnosed a fuel problem. A new fuel pump was fitted, it wasnt that. The Fuel injection ECU was tested, it was good. Engine sensors were replaced, then the Marelli ecu was discoved to have water damage, . This too was replaced. Total cost of £1000+ Fault cured! A mere 300 miles later the fault returns as before. Any ideas please??? I have since discovered the route of water, it came in through rust holes under wiper grill.
Best
Pete
Steve
Platinum
My first thought was that the ignition amplifier is no good. I had a similar issue with an XJ12 that I owned. Maybe one of the Jaguar techs that frequent the forum will be able to chime in on this.
HEALEYJAG
Hasd same problem with my 12 cyl e-type....turned out to be vapor lock from using fuel with an alchohol additive.. Ran straight gas...no problem.
Steve
Platinum
I don't think that they have the same fuel issues in the UK as we do here....
I don't know how to go about testing the new amp, back in the day the only proper way was to swap it out for another unit which was known to be good. You can put better, more reliable electronics into the original casing nowadays as well. Just in case.
Platinum
Another consideration: the injection system is very voltage sensitive where it comes to supply voltage. Check to insure the battery and alternator are up to standard.
jessebogan
Were BOTH crankshaft position sensors replaced? Also, check the connections at the coils. The small wires are prone to break where they go into the connectors. The coils themselves are also suspect. The ignition rotors can short to ground. Remove the distributor cap and then the rotor. Look at the rotor closely for signs of burn through at the center shaft. What spark plugs are you using, and what are they gapped to? The CORRECT gap is .025. Most people ignore that little setting. Check these things, and get back to us.
Michael J.
Jessebogan is on the right track.
1st check the connection for the front crankshaft sensor for corrosion inside the plug. Connector is on right side of AC compressor in the valley of the Vee. The connector is black and looks like one of the connectors on the fuel injectors. I used an emery nail board to clean the pins when corrosion was found.
If not in the connector, look at the top of the sensor. It mounts just under the harmonic balancer at the rear of the under pan. There will be corrosion or other signs that the sensor is failing.
I now carry an 8mm wrench and a spare sensor in the car at all times. The sensor is relatively cheap (about $55) and I have had to replace the front three times in the last 8 years. The rear seldom fails, when it fails it won't count the teeth on the flywheel and the car will not start. The front sensor is exposed to wet conditions and seems prone to failure.
V
vfr2009
Jesse, thanks for your reply much appreciated, one question are you sugesting there are two sensors on the crankshaft? the Workshop manual only mentions one?
jessebogan
As the above post mentions, there are 2. Main sensor is at the front, under the crank pully. The other is mounted at the rear, on the bellhousing cover plate. It is in a prime location to get oil soaked , but it still has a much lower failure rate than the front sensor. It's connector will be found near the large crossover pipe that connects the two intake manifolds.
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Popeye TR4/4A Transmission noise - intermittent Triumph 22
B Intermittent Loss of Electric Power Austin Healey 18
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
