Intermittent Misfire
Griz
My BJ7 has developed an intermittent misfire while cruising. It is most notable in 3rd and 4th gear, but somewhat evident in 2nd gear too. It really doesn’t show up until the car is fully warmed up. There is never any misfire while the engine is under load or accelerating through the gears. I have conventional points and condenser ignition. Plugs, wires, and coil are new within the last 500 miles. Any ideas for a “fix”?
Griz
steveg
Re: Misfire
Ideas - no particular order:
--condenser
--broken ground jumper wire between movable and fixed distributor plates. Sometimes they break internally, causing intermittents.
--loose or internally broken primary wire - try jiggling it with the engine running.
--try disconnecting black/white wire from battery switch to distributor.
--float level. I had an Alfa that would 'hunt' while cruising on the freeway - a Weber specialist told me incorrect float level could do that.
Griz
Griz
Re: Misfire
Thanks for the ideas Steve, but I still don’t understand why the misfire never happens under acceleration.
steveg
Re: Misfire
Another idea - it's running lean at cruise, maybe due to throttle shaft leakage. When accelerating, the piston damper richens the system, getting rid of the miss. Would you get the miss going up a long grade at a moderate speed in an intermediate gear?
Did you try richening the carbs overall?
Is the idle irregular?
Condensers have been a problem all along. I like the yellow-wire condensers sold by Distributor Doctor, which are supposedly made to original Lucas spec.
Keoke
Re: Misfire
What type spark plugs are u Using???
Lin
Re: Misfire
Hey Steve,
as you know I have been using a 1-2-3 distributor. I am having Jeff rebuild my original Lucas unit. I may switch back to original. Which condenser do you use from Distributor Doctor?
His site says: applications.
407044 fits DX/DY/DZ & DVX variants & has the bracket in the centre.
400308 fits DK4A/DK6A with the bracket at the end.
484249 fits DJ4/DJ6 /DJ4A/DJ6A.This has the long tail bracket.
Thanks,
Lin
Griz
Griz
Re: Misfire
Does not miss when pulling a hill, just while cruising at steady speed. One thing I have noticed since the misfire started is that the exhaust really snaps and pops now when I downshift. Used to get just a nice burbling sound under compression. I’ll have to check but I can’t recall what plugs are installed.
red57
When you're cruising at steady state and it starts misfiring, try pulling the choke a small amount (enough to drop the jets a bit) - that should tell you if it's caused by a lean condition.
Dave
Griz
Griz
I’ll give that a try Dave, but the car is not running hot as it would if it was lean. And to answer Keoke’s question I’m running Autolite AP 65 plugs.
TimK
A leak in the gasket sealing the exhaust down pipe to the exhaust manifold (usually due to a loose nut) allows air in to ignite unburnt exhaust mixture causing pops rather than burbles.
Griz
Griz
Tim, they were a little loose. I’ll take a drive later in the evening after it cools a bit (it’s like 95 here today) to see if the exhaust pop remains.
Michael Oritt
When the car is accelerating the centrifugal advance causes the plate within the distributor to move, and this could be pointing to the problem: a bad wire or connection in the points set.
OTOH my experience is that leaning out the mixture causes more "backing down" or snap/crackle/pop sounds, which is not necessarily a sign of the carbs being set too-lean, just leaner than otherwise, and reading the plugs after a hot shut-down should tell the tale on that.
If it was me I'd start with the ignition.
Look for a spark leak. In a dark but ventilated area run the engine at cruise speed and look for arcing on distributor cap or secondary wires.
Madflyer
You did not add distributor cap or rotor to list of new parts. Check the cap for white lines on the inside as cracks. you may not know if you are getting full power from carbs as you accelerate. This is due to linkage The capacitor could be the problem as they are cheep and are used to short out spark between plug wires as not to burn points. Also the post about the flyweights under the points mounting plate could add to the problem. Moss sent out some junk rotors what color is yours. What does it do if going down hill long grade if popping when you back off popping says ( tinning is off ) My TR 6 lives at 4,500 feet and when I go down to sea level it is to lean and will go flat at high speed I add a 1/2 turn to carbs richer but that not your problem but tells you what lean does. Madflyer
Griz
Griz
Ok you guys have given me several things to check out. Most will have to wait until tomorrow, but I can report that pulling the choke out slightly while driving did nothing for the misfire, and there are no telltale arcs under the hood in the dark. Distributor rotor and cap are about 3 yrs old. Rotor color is rust red.
johnea
Check your vac advance canister. If it's leaking, it would give no additional advance while cruising. That might cause a misfire.
mgtf328
See my post on 'Problem Solved', earlier this week. Check the vacuum lines to the brake servo and the dizzy. I had a crack in mine that caused the same problem.
AJ
nevets
I also had an intermittent misfire issue that only appeared when the engine was fully warmed up. Turns out it was the ignition coil. Seems that an aging coil will not function properly when it gets hot. Swapped out the coil with a new one and the misfire disappeared. Not saying it's your problem, but if you have another coil handy, it might be worth the 15 minutes or so it will take to try it out.
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Popeye TR4/4A Transmission noise - intermittent Triumph 22
B Intermittent Loss of Electric Power Austin Healey 18
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
G Misfire After Prolonged Idling Austin Healey 16
warwick-steve Misfire mystery Austin Healey 28
CLEAH Another BJ8 Misfire Question Austin Healey 11
4tecdog Misfire at high revs Austin Healey 21
TulsaFred Engine Misfire Spridgets 6
R Healey BJ8 misfire Austin Healey 5
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
justin_mercier Wedge Need help diagnosing a misfire / stutter / stalling when stepping on gas Triumph 8
MY66AH NO FIRE! Misfire Spridgets 12
richberman Stuttering and misfire likely cause? Austin Healey 18
JPSmit Tonight's question -Mazda misfire Other Cars 2
O TR2/3/3A TR3 Misfire +[ Randall you're correct again] Triumph 10
M TR2/3/3A TR3A Misfire Triumph 8
W Spitfire Misfire on all 4 cylinders - '80 Spitfire Triumph 7
