Engine Misfire
TulsaFred
my home rebuilt 1275 was doing fantastic, pulling smoothly through all gears and speeds without the least issue.
I was working on the generator and control box, and when I took it for a test drive it is not showing a pretty severe backfire issue that seems mostly at mid rpms on the lower gears under load. At higher speeds it is not apparent.
I wondered whether I might have bumped the dizzy cap or wires while wrenching, but nothing obvious on inspection.
I have an uninstalled points/breaker plate/red rotor from Jeff at Advanced Distributors so I suppose now might be a good time to install them.
Any thoughts on a diagnosis? The engine only has about 50 miles on it.
nomad
Sure your valves are adjusted correctly? Most likely ignition but another base to cover.
Kurt
TulsaFred
TulsaFred
So I got it fixed. I changed two things at once: pulled off the Moss rotor and replaced it with a red rotor from Jeff at Advanced Distributors (had one on the shelf waiting to go on). The other thing I changed was a faulty Lucas control box.
I am pretty sure it was the control box, which had not been working and did not allow charging of the battery. The voltage on the battery was only slightly low at about 12.4 volts, but without the generator adding some juice it seems like this was enough to make the spark too weak.
With the new control box the voltage goes up to around 13.8 volts with higher rpm.
I never would have thought this would cause a misfire problem, but it did.
drooartz
Well done!
nomad
Low voltage causing a misfire would make me suspect that the coil might not be up to the job. If you have more trouble I'd sure try swapping the coil.
Kurt.
TulsaFred
TulsaFred
good thought on the coil, I have a bosch blue coil waiting to go in!
P TR4/4A TR4A Engine Misfire? Triumph 5
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
