TR4/4A TR4A Engine Misfire?
PlaidMan
#1 cylinder ignites fuel sporadically. No vacuum leaks that I could find, new Pertronix. There is firng at #1 cylinder,however with engine warm and idling , you can disconnect #1 plug wire and their is no change in the idle. The engine runs strong under acceleration but when held to constant rpm, it tends to rock the car back and forth a little , I'm thinking it's igniting the fuel sporadically. It does this at all rpms , just more noticeable at lower speeds. What do yall think the problem might be? Also, new spark plugs ,ignition parts new, carbs check ok, verified the spordic flaming with the colourtune system. All the other cylinders igniting correctly.
G
Charlie, are you familiar with Jim the mechanic over on Cameron St.? Coming from Amb. Caffery, turn right on Cameron and look, after a few blocks, on your right. Jim ain't much to look at (looks like a Harley dude) but really knows British sports cars and won't remove your eye teeth. Probably worth your time to buzz over there and have him look at your problem. I have used him off and on for 20 years, knows some stuff.
Bill
P
PlaidMan
Thanks Bill for the Mechanic info,I'm sure it will come in handy for me. Andrew, changed plugs with another cylinder and also the plug wire, no change. It must be a mechanical problem because I verified firing using the colortune, only on #1 cylinder it showed an intermittent blue flame, #2,3,&4showed a consistent blue flame at idle. #1 cylinder is igniting the fuel every so often even though it has a consistent spark. Must be valves, rings, valve springs, whatever. Does anybody have any theories about what is happening in #1 cylinder? Thanks , Charlie
TR4nut
Yep, compression check would be a very good and easy diagnostic. Another fairly painless thing you could do is pop off the valve cover and see if at least the valves are moving properly before you get more serious.
But maybe this still could be electrical - hows your distributor cap and rotor? Switching wire and plug won't fix that if the problem is internal to the distributor.
Good luck!
Randy
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
KVH General TR TR4A Engine Won't Start Triumph 34
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
S General TR Engine Serial Number Question - Observation on a TR4A Triumph 3
H TR4/4A TR4A engine mounts Triumph 4
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
R TR4/4A TR4a engine compression Triumph 6
T TR4/4A Fired the 67 TR4a IRS engine today Triumph 5
T TR4/4A Date range for this TR4a engine Triumph 8
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
T TR4/4A TR4a engine mounts - round vs rectangular & vendor Triumph 13
CinneaghTR TR4/4A TR4 v. TR4A engine mounts? Triumph 4
TR4nut TR4/4A Engine upgrades from a TR4a - what to get? Triumph 11
Paulus TR4/4A TR4A Engine runs on Triumph 11
PeterK TR4/4A TR4A engine block tag Triumph 2
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
