TR4/4A TR4 v. TR4A engine mounts?
TR4A_IRS
One would assume the 4A mounts are better, as they would have been an "improved" design. When I bought my car, the engine mounts were so bad that the fan pulley was rubbing on the steering rack and now has a nice groove in it where it was rubbing. I ordered new engine mounts and somehow got the older style mounts, and they did not locate the engine properly. I replaced them with the proper 4A stlye and have been happy with them for almost 15 years.
KVH
I bought two types: The rectangular ones from Moss, and the "new" round ones for TR4As from BPN.
After carefully examining both, and measuring the thicknesses, I went ahead and installed the rectangular ones from Moss. They work fine.
But most importantly, I slipped two good sized steel washers over the bolts before letting the engine back down. The extra space of about 1/4 inch on each side between the mount and the front engine plate foot is very nice to have. Prior to then, the clearance was ridiculous and the pulley extension was hitting the cross bar as I went over bumps in the road.
From my experience, and others on this Board have agreed, it's worthwhile to install those spacers (which can also be installed after the fact, by just loosening the mounting bolts, jacking under the oil pan, and sliding the washers down onto the bolt after cutting a "slot" out of each washer so it will slide horizontally onto the bolt under the foot of the front engine plate).
Good luck.
CinneaghTR
CinneaghTR
Thanks, guys. A while back, I had ordered the "improved" QH 4 mounts from BPNW, but I might break the piggy bank and order the 4A ones from Moss. The 4A mounts in the car now were supposedly new and since the fan pedestal was rubbing, I assumed that I needed something different. My Dad took one look at the current mounts and said they needed to be replaced.
I'll get some spacers and start preparing them while I'm at it. I am afraid of getting too much height and having the thermostat housing hit the hood, but I'll keep an eye on it.
trfourtune
why don't you just shim the new mounts you have. The improved mounts are supposedly an improved rubber (probably a stiffer compound). Not possible??
Rob
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
J TR4/4A TR4a exhaust on a TR4 Triumph 4
K TR4/4A TR4 and TR4A Hardtops Triumph 9
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
D TR4/4A TR4/TR4A Top questions Triumph 3
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
J TR4/4A TR4A radiator install into a early TR4 ??? Triumph 14
D TR4/4A TR4 TR4A Hardtop Triumph 9
M TR4/4A Tr4 Tr4a door handles Triumph 2
TR4A_IRS TR4/4A TR4 vs. TR4A flywheel question Triumph 19
Gerald_Gordon TR4/4A Radio for TR4 or TR4A Triumph 18
doughairfield TR4/4A TR4a exhaust manifold on a TR4? Triumph 6
R TR4/4A tr4 / tr4a seat frames Triumph 9
HerronScott TR4/4A TR4/TR4A parts car in NY? Triumph 7
T TR4/4A What to do with these TR4/TR4A inner fenders? Triumph 7
T TR4/4A TR4 vs TR4A grills Triumph 3
T what max size tires & wheels fit a tr4,tr4a,tr250? Racing 3
K TR4/4A TR4 and TR4A Grilles Triumph 2
KVH TR4/4A TR4/TR4A Oil Pan Bolts Triumph 4
Alan_Myers GT6 TR4A w/surrey, TR4 & two GT6s FS in SF Bay Area Triumph 0
SCguy TR4/4A TR4a parts car for my 62 TR4? Triumph 5
SCguy TR4/4A TR4/TR4a Questions Triumph 20
J TR4/4A Better Breathing TR4 vs. TR4A Valve Cover Triumph 15
M TR4/4A TR4A Clutch on a TR4 Flywheel Triumph 3
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
V TR5/TR250 difference on surrey tops tr4 vs tr4A/250 Triumph 2
A TR4/4A Soft top - TR4 vs TR4a Triumph 8
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
