[ QUOTE ]
Alan,
I am adding a TR6 dual MC/servo setup to my 4A and have a catch can too. Have you any thoughts about how I could/should split/don't split the vacuum source? I was planning to route the servo straight to the manifold vacuum through a non-return valve; then output the valve cover port through the PCV and then to the catchcan (filtered).
Do you really think I would need a vacuum source for the PCV? Or is my setup OK? No plans for a draft tube although I have seen a race setup (Revington) with the draft tube post routed to a catch can as well as the PCV.
Ideas or suggestions?
[/ QUOTE ]
Hi Peter,
I really am not sure I can be much help. In my earlier response, one thing I failed to mention is that I have no vacuum source on my car... It's fitted with Weber DCOE carbs and a Warneford manifold which I don't want to imbalance with any vacuum ports. For that reason, DCOE fitted cars are usually converted to a mechanical advance only distributor and manifold vacuum ports are closed off. (I have run DCOE successfully with vacuum ports in the manifold, but it makes them difficult to balance.)
In addtion, a higher duration cam such I'm using might reduce available vacuum at low rpms in particular. Since a cam upgrade is often combined with a Weber installation, this is probably another reason DCOE installations are not normally fitted with vacuum sources.
So, those are the reasons I'm looking at alternatives, such as an electric vac pump of some sort.
My primary purposes for a vacuum circuit on the crankcase is to improve cylinder sealing and draw off some of the contaminant fumes typical in any crankcase. But, it's entirely possible I'm just over-engineering the whole thing! /ubbthreads/images/graemlins/crazy.gif
It sounds like your setup should work. I'm working without a PCV and was thinking instead of using a catch can that doubles as a vac reservoir, controlling the amount of vac with a release valve/breather that essentially does the same thing, and routing hoses from the valve cover and the crankcase (the latter with an oil trap). The only thing I'd be concerned about with your design is that you might want to be careful that there's no way traces of engine oil might find their way into the vacuum side of the brake servo. I don't know for certain, but that might be a problem.
Elec vac pumps and vac reservoirs are used a lot in power brake/servo situations like yours, when a high duration cam that tends to reduce available vacuum at the manifold in low and mid rpm ranges, in turn effecting the brake servo. So, one manufacturer of the elec. vac pumps is Stainless Steel Brakes. But, their pump is pricey and not really designed for an oil rich environment like crankcase evacuation. It's really just intended to supply a brake servo.
I know at least one alternative source of vacuum: the exhaust. A drag racer trick for crankcase evacuation is to weld a couple 1/2" approx. tubes into the exhaust. Those have slanted tips cut on the ends and as exhaust gases flow by a vacuum is created (much like the larger open air crankcase draft tube on the TR2/3/4). Of course, using the exhaust that way is not street legal or very environmentally correct, since it will pull some fine oil mist out of the crankcase and send it directly into the exhaust. I really can't say if this would work for brake servo purposes.
Hope this helps!
