Would this maybe be a better path to take?
terriphill
If you have been following the "Alfa saga" you know I am having nose problems....here's a question: Do you think this might be a better path?
Alfa nose replacement
It appears to be a cut, weld and patch job...I'm not sure I have the energy or muscles to pull it out and bang it out again.
Platinum
IMO, that's the "path of least resistance" Terri. Just be careful ya don't get sucked into a "might as well" situation. :wink:
Popeye
Bronze
I guess my "rule of thumb" (from my thumb-sized brain :smile: ) is, if there is no rust and no sharp creases, bang it out.
Sharp creases / stretched metal can be tricky - but are not impossible, and then it becomes a question of time vs. money.
Also, some sheet metal is more $ than others. The nose, $130, is not too bad; I'm doing some rust replacement on wheel arches on my TR4A where each wheel arch is around $350... so I'm learning to make compound bends in sheet metal!
Gray_Cat
Seems like a very decent price and would expedite repairs. You can take your time repairing the damaged nose and have a spare in case this happens again and you will have a replacement to go right back on!
Roy
Not a bad price... for a nose job.
But if it needs welding, if not done well that could cause distortion and be difficult to fix.
tony barnhill
Great Pumpkin - R.I.P
$135.00 + $48.00 for shipping = $183.00
Do you have the equipmment to put 'lips' around it or the body so they fit together for welding?
T
terriphill
Tony, what do you mean 'lips' is this something that we have to have to hold it in place while we weld?
tony barnhill
Don't know exactly how to describe what I call "lips" other than to say one piece of metal is flat & straight & the other piece is crimped so that it's edge slides up under the 1st piece's edge & then the weld is made where to 2 pieces come together....can anybody else explain it better?
This shows a "joggler" being used to create a "lip"- a slightly lowered flange to which another piece of metal can be attached with spot welds and the joint then either filled (lead loaded preferably, or plastic if that's what you want) or neatly welded. Easier to do than a butt joint that welds them edge-to-edge. More properly this is called a lap joint, and is very common.
Edited to add:
These can be easily clamped in place too with welding clamps (like big "C" clamps) where the sheet metal allows access,
and there are "pin" type clamps that require holes to be drilled in the flanged joint and then used to clamp the pieces where access is not possible.
tony barnhill
Thank you, James
Popeye
Bronze
One comment on the lips - the joggler will stretch the metal, causing some distortion in the metal.
I find it helps to joggle before doing the final fit-up and tweaking of new sheet metal.
T
terriphill
Thank you so much James! That is a great help! Since David is actually going to be the one doing this type of work (I can't weld for anything...I try but I think it may be years before I'm willing to come near a car with a stick in hand!)this is a awesome! :smile:
tony barnhill
bgbassplyr
I have HF flanger. Works great.
Bayless
Handy tool. Used it to punch holes in the VW replacement floor for welds to duplicate the original spot welds. At every 30 mm or so, it would have taken a very long time with a drill.
E Off Topic Useful for saving some cash maybe? MG 0
Basil Virtual Rally - maybe Other British Cars 0
Basil Virtual Rally - maybe TVR 0
Basil Admn Note Virtual Rally - maybe Triumph 0
Basil Virtual Rally - maybe Sunbeam (Rootes) 0
Basil Virtual Rally - maybe Spridgets 0
Basil Virtual Rally - maybe Rover / Land Rover 0
Basil Admin Note Virtual Rally - maybe MG 0
Basil Virtual Rally - maybe Lotus 0
Basil Virtual Rally - maybe Jaguar 0
Basil Virtual Rally - maybe British Motor Corp 0
Basil Virtual Rally - maybe Austin Healey 0
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
Mickey Richaud General MG Victor [Maybe] On Ebay MG 12
S TR2/3/3A tr3 maybe Triumph 7
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
bcliff MGB Are you looking for and MGB Roadster or maybe something else. MG 5
D TR4/4A unidentified, but maybe a manifold piece? Triumph 16
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
D TR4/4A flywheel bolts maybe too long Triumph 15
waltesefalcon Panteras, maybe Panteri? Spotted 0
B TR2/3/3A Another/maybe the same fuel delivery problem Triumph 5
J Cloth interior in AH-3000? Was it ever fitted? Pleated inserts maybe? Austin Healey 7
B Maybe selling my Bugeye? Taking a poll - Spridgets 18
HealeyRick TR2/3/3A Maybe I'll Rethink being a Healey Guy Triumph 8
F Too much procrastination[maybe long winded] Austin Healey 9
KVH TR4/4A Want to Buy This one: For Maybe $50,000? Triumph 3
bugedd The journey begins....maybe Spridgets 9
RickB 5 speed or maybe clutch noises? Spridgets 28
M_Pied_Lourd Maybe I am just Slow..... Triumph 15
Jeepster Maybe I should sell my Healey and buy a boat? Austin Healey 9
KVH TR4/4A TR4 OD Maybe Last Question Triumph 2
RickB Maybe a new small 5+ speed trans-plant?? Spridgets 6
pkmh BJ8 Stalling Problems resolved [maybe??] Austin Healey 13
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
S old question maybe?, rebuilt engine Triumph 3
jsfbond Wedge TR7's for sale.......maybe? Triumph 4
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
V Dog? Maybe not Triumph 4
Tabcon "Gone in 60 Seconds"....maybe. Jaguar 4
C A fuel problem, Maybe, maybe not Spridgets 22
P TR6 Maybe Selling a 76 TR6 Triumph 4
RickB MGC Maybe selling the 69 MGC GT - what's it worth? MG 39
T TR2/3/3A Wanted [maybe]..a restored TR3 for $25K or less... Triumph 0
MTribe Help tracking leak -- maybe rear lifting eye ?? Triumph 26
R6MGS MGA MGA Engine noise??? maybe? MG 11
N Maybe a little extra! Triumph 2
J Spitfire New 69 Spitfire owner here to read and maybe post Triumph 12
