Better to be lucky then good!!
ralph_s
I've been wresting w/ the removal of my BE's 1/4 elliptical rear springs. Lots of soaking and tapping and waiting. Well 3 of the 4 bolts came out w/o a hitch. The 4th sheared off at the head. After lots of thought and trying anything to avoid drilling I played with thought of rotating the spring assembly. I dug out tons of dirt/rust and who knows what to make as much room as possible and then placed a bar through the end of the spring and strated to rotate clockwise. After some wiggling, twisting and a break for a cold one, the spring rotated in the box and came out w/o any issue. I could then place the spring on the bench and work to remove the stuck bolt. All ended well and saved me quite a bit of time.
Anyone have a recommendation on a reputable source to refurbish the springs?
Your work bench, nothing there you can't do yourself.
Thanks Jack,
I'll have at it myself. Any tips on what to avoid and/or do?
Make sure you can find new clamps for the springs. Shop that services small boat trailers could likely help.
The small clamps that go around the springs are unobtainum as mentioned.
JPSmit Sometimes it is better to be lucky than good Spridgets 15
JPSmit OT but sometimes it's better to be lucky than good Spridgets 9
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
John Turney Need a Better Demister? Austin Healey 5
S TR2/3/3A understanding the float and needle set up better Triumph 6
Michael Oritt Towards better brake performance.... Austin Healey 28
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
C A better sound for a Miata? Other Cars 0
C runs better without air cleaners?? Austin Healey 19
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
Got_All_4 General Tech Different style synchros which is better Triumph 4
Pythias Back and Better Than Ever. Spridgets 7
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
RedTR3 TR2/3/3A New is better? Triumph 14
B Everything runs better with this mod - all models!!! Spridgets 7
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit Ms Triss is better not best Spridgets 14
glemon Better Move Fast Spridgets 4
bugedd Better hurry if you want your master sleeved Spridgets 12
Got_All_4 Wedge Now that's better ! TR7 brakes Triumph 1
Mickey Richaud Ain't Nuttin' Better! MG 7
C OT - Are Alfa's better? Triumph 19
Nelson Better than cardboard? Spridgets 52
TR6BobNF Big Old Cat - Better Pics Jaguar 5
PC They couldn't do better than....? Other Cars 25
BugeyeNJ58 Need a Better Muffler for 59 Bugeye Spridgets 5
T TR4/4A Which TR4a is better - IRS or solid axle? Triumph 30
Gundy heeding my better's advice Spridgets 162
MCNX_BFF Triumphest 2010 pix --Better late than never? Triumph 4
J TR4/4A Better TR4 Valve Cover Replacement? Triumph 8
DNK Better Tail Spotted 4
M Better head gasket for a 1500 Spridgets 26
M Better carb heat shields to deal with vapor lock? Spridgets 18
I Bugeye-better to have negative or positive ground? Spridgets 17
UmmYeahOk Which is better - Carb Related Triumph 2
billspohn Better Than Snow Tires MG 9
J Need a better fan Racing 0
Hap Waldrop Beer run pics, better late than never :] Spridgets 6
T Would this maybe be a better path to take? Restoration & Tools 15
M TR2/3/3A How do you get a TR3 to ride better? Triumph 19
jaegzie Which way would be better -- Body Work Spridgets 5
T 30 minutes of clean up and much better Triumph 19
Stick Car runs better with vacuum leak? Spridgets 4
healeynut My A90 Atlantic is better than your SP250 Other British Cars 10
T How can I get better fuel efficiency Jaguar 15
T Speaking of O2 sensors... two better than one? Triumph 18
lbc_newbie someone better jump on these!! Spridgets 5
Pythias Better---FINALLY! Spridgets 9
TRnorwegian Japanese gear box better? Triumph 29
