You Tube made me do it. I bought a Milwaukee dry cut saw.
DavidApp
Just used my new toy for the first time on the car project cutting strips of sheet for the floor support repair. Probable overkill for the job but what a joy to clamp a straight edge to the steel sheet and just zip off a strip in seconds. Straight edge no burrs.
It is said to be able to cut up to 3/4" steel plate! I can see a lot of uses in the future for it.
A Northern Tool buy.
David
Popeye
Bronze
Very interesting! Can you tell us more? Which u-tube video. How does it work... curious minds want to know!
(Per a Google search on "Milwaukee dry cut saw" leads me to a page on the Milwaukee Tools web page, stating the product is no longer available - similar to the first Northern Tool hit.)
JPSmit
Very cool! and a worthy addition, and at the same time all I can imagine is explaining to SWMBO
"yes dear and not only that, remember when you had all that 3/4" steel plate to be cut? Well now I can do it!"
:yesnod: :whistle: :lol: :banana:
DavidApp
This thing is opening up all sorts of avenues.
I have some 1/2" x 3" flat that I have had for some time. Every time I need to use a piece it was Hack Saw time now I can just wizz a piece off in seconds.
Going to make top plates for my axle stands so they will have a nice surface to go under the TR3 frame.
David
Sarastro
That seems like a great tool. I never knew such a thing even existed. Now I have a problem...
But I know the situation. Here's what the internet forced me to buy. It's a Miller 211 MIG welder. Runs off 220V or 110V, but it makes good welds in surprisingly thick metal even on 110V. It is largely automated--you set the wire size, metal thickness, and type of gas and weld, and it sets the wire speed and power. It sounds like a cute idea that wouldn't work well, but it actually works quite nicely. After struggling incessantly with my old, cheapo welder, this one is a dream to use.
A Dipstick tube not made anymore? MG 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
D TR2/3/3A Vacuum advance tube Triumph 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
T Tube shock conversion BJ8 Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
TomMull TR2/3/3A Brake tube Triumph 18
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
B Posting non you tube video? FORUM Navigation Questions 3
