Tube vs Tubeless discussion :]
AUSMHLY
Classic Car Performance is a reseller of MWS/Dunlop wheels.
They say on their website, Austin Healey / MG / Morgan / Triumph - Spoke Chrome & Tubeless (assuming it’s the Dunlop wheel).
The spec sheet says: “Style…Tubeless. (Dayton’s attempt at this wheel requires a tube)”
https://www.classiccarperformance.com/products/xw452-wire-wheels?variant=9579335516207
Through the years, have the Dunlop wire wheels been modified or redesigned to now run tubeless?
Anyone running tubeless? How often do you have to monitor the air pressure?
Seems to be another.. tubeless vs tube discussion.
I've run Dunlop wires tubeless for over 15 years, never an issue on my '65 BJ8.
I have purchased a pre loved set of chromes - stamped - Made in India, and we know who sells them. They have actually been sound as a pound with the Tubeless tires since I bought them 3 or 4 years ago. My only complaint is that the chroming is a bit naff and requires a lot of attention to keep them pretty and small rust spots are appearing. I think that you need to keep cleaning them on a regular basis with a good chrome cleaner to keep the old rust at bay. Looking on the inside of the rims they have covered the area of the spoke nipples with a continuous bead of some blackish super swishy sticker to effect the seal.
:cheers:
Bob
I have tubeless Dayton 72s on both my cars , not a problem , chrome is still like new . Check the pressure maybe twice a Season .
Tubeless, how is the repair done when a spoke breaks?
Do tubeless wheels have a rubber strip (rubber band) over the inside center or is a type of tape used?
Once a spoke is replaced, wheel needs to be air tight again.
John, Dougie, your days are numbered guys, eventually a spoke will break. It's inevitable :(
No comment on:
No comment on:
72 spoke wheels are stronger and Daytons use Stainless steel spokes , they guarantee they will not need to be retrued .
also they have a thick bead of what looks like silicone rubber over where the normal rimband would go .
I dont know anyone who uses Daytons that has had issues or broken spokes .
As I break a lot of spokes I use tubes. Some tires say they require tubes (Michelin) one the side walls. Moss sells the bands that protect the tubes. Plumbers tape works very well with two or three layers (cheap). This is what BCS does. Next time I need to dismount the tires I will use the bands as I think I can sneak under to replace the spoke. The tape curls when I do that.
After you do a serious clean of the chrome wheels, spray them with spray on wax (Meguires). They will then clean off easily with water.
No comment on:
I'll let the next generation worry about that.
No comment on:
I travel all over the country so I use tubes trying to get a tube or tubeless repaired today is almost a joke.
Simplicity just says carry a good spare tube.
On the other hand: 72 spoke wheels with SS spokes are not prone to spoke failure IMOP.
IN either case tubed or tubeless, just have a spare tube with you in case of a puncture.
Over the last 10 years, I've had 2 stainless spokes break on my 72 Dunlop wheels.
I'm not driving hard, never been on a track. I've always thought, more spokes, distributes the load better, hence less breakage. Yet I've had 2 spokes break on the 72 version.
I wonder if more spokes break on the 60 spoke vs 72. Sure some will say, I run 60, never had one break. I run 72 never had one break. Wonder what a poll would come up with.
Maybe spokes simply break every now and then; regardless... it's part of running wire wheels.
Over the last 10 years, I've had 2 stainless spokes break on my 72 Dunlop wheels..
See you should have bought Daytons ........
Daytons, Dunlops, both 72 stainless spokes...
Reminds me of the joke: Man gets a red and blue tie from wife. Wife; try one on. Man puts red tie on. Wife, what you didn't like the blue tie?
OR...See you should have bought the disc wheels.....
I had 48 spoke wheels as originally supplied with the 100. I got to the point where with some grunting and a set of Dunlop and tire irons, I could change a spoke without removing the tire or the tube. Not fun, especially breaking the bead free of the rim if it had been a while. Because I am( or was at any rate) a sick son of a gun ("Do it all youself, you'll be glad you did" is evidence of that) I mounted all 5 tires by hand when I did my rebuild. I'm too old and cranky now for that routine. I love my Minator tubeless knock off wheels. Only 8 spokes, but oh they are beefy.
My pre-loved are 60s and tempting fate - I have had no probs since I bought them.
The super swishy sticker that was used to seal them looked to be a kind of rubber, similar to the seam seal that I can get from my local paint factor, but it may well be black silicone.
:cheers:
Bob
Daytons, Dunlops, both 72 stainless spokes.......
You didnt read the fine print on the website ......the bit about guarantees etc . Theres a big difference from what I remember .
Yeah But:[h=1]tainless Steels Classifications [/h]
[h=2]Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels '[/h]
So U really do not know what you have unless U ask.
A magnet can help you decide good or bad>
F Tube or Tubeless? Spridgets 2
A TR2/3/3A TR-3 tube or tubeless-Tire Experts? Triumph 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
D TR2/3/3A Vacuum advance tube Triumph 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
T Tube shock conversion BJ8 Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
TomMull TR2/3/3A Brake tube Triumph 18
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
