Modern pistons for a 3-main B-series engine
mjamgb
I'm rebuilding my 3-main MGB engine to go in a Magnette. I am going for smoooooth power and reliability. I want a modern piston/ring design rather than the monster lumps the factory supplied. Anyone have a source they really like or advice?
The engine will have several modifications for reliability including lightening, balancing and upgrading as necessary (I've done a few of these in the 5-main format).
No, 10,000 rpm isn't in the cards, just smoooth cruising. /ubbthreads/images/graemlins/angel.gif
Platinum
If you want to go with REALLY spiving jugs, Wiseco, in Mentor Ohio will MAKE 'em any way you want. Not cheap, but decidedly "custom."
mjamgb
mjamgb
Ja, Arias, Keith Black, Ross, etc. will all do that, I was hoping someone has experience with "off the shelf" stuff that wasn't cast in India from the same molds used since I was born.
aeronca65t
Try AE Pistons. A set around 9:1 comp ratio would be nice for a street car (but you can get higher). Here's one source that probably has them (but AE are pretty easy to find from various suppliers):
https://www.aptfast.com
Platinum
AE seemed too "mundane", from the way I read the post... but they're all I've ever used in B engines. I got a set of jugs made for a V-12 Ferrari from the Mentor outfit, faster and cheaper than from It'ly.
Sorry for the gap in my understanding there, Mike!.
Dave Russell
Yoda - R.I.P
IMO, Deves makes about the best rings that you can get.
https://www.deves.com/about.html
As far as pistons, Venolia makes some of the strongest, lightest, most precise pistons that you can get. However, they are forged instead of cast & require a bit more cold clearance than cast pistons. After a very brief somewhat noisy warm up they are as quiet as any others. The price may not be that much more.
https://www.venolia.com/
I believe AE is a cast piston. Requires less cold clearance, is heavier, & not as strong. Maybe all that you need though.
G
If you want to spend that sort of dough, get something made from a hyereutectic alloy, they are low expansion so you can still run the same piston:wall clearance as stock. That way you get the benefit of a forged piston, but no slap.
They are not exactly cheap though - mine ran about 2x the cost of a set of Hepolites, and because they were custom I ended up waiting 3 months for them.
Deleted member 3577
I have heard that hypereutectic pistons (>12.5% silicone) are very susceptible to detonation failure.
Any truth to that, or is it just Chicken Little talk?
G
I've only ever heard of it being a problem for high boost turbo engines with poor detonation control. I doubt that that's what we are talking about here though.
mjamgb
mjamgb
OK, so, is the consensus that ALL new pistons are of a new design (including 3-main units)? Perhaps I'm showing my ignorance but are the 3-main pistons actually different from the 5-main units other than wrist pin? Maybe It's not the issue I thought it was. I know the rods are two different flavors. If the wrist pin diameter is the same as the 5-main pistons then I should be able to use them?
trfourtune
JE makes anything you want and they have a forged street stock alloy that has a lower expansion rate that is designed exactly for the hot,hottest, pump gas, street motors. those are what i am considering for my 10:1 comp triumph tr4.
rob
Matthew E. Herd
If it's any interest, my pistons are JE forged (and it took forever to get them). But I am running a 1500 midget at 10.5:1 + CR and using Sunoco Ultra 94 with absolutely no problems. 93 Octane works fine in a pinch too. No problems with knocking, and the car really screams.
billspohn
No, you can't run 5 main pistons in a 3 main engine. You need the correct wrist pins.
I LIKE the 3 main 1800 engines a lot. I've raced several cars with them.
billspohn
I have run AE (Hepolite) .080" over cast in my 3 main back-up 10.5:1 race engine and never had a problem. Great for the street too.
For the race engine (MGA Twincam) I use custom built Ross Racing forged as with 12:1 and a 7800 RPM red line, you don't want them coming apart on you. That's overkill even for a hot street engine though.
Platinum
I've had NO problems with AE's in five main mills, even built some 10.5:1 "street" engines with 'em too.
DrEntropy Some crabbing about 'modern' cars Other Cars 11
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
M TR5/TR250 Compatible Modern Tire Size Triumph 5
glemon Modern Cars [and some perspective] Other Cars 9
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
M Fitting a modern radio Austin Healey 9
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
billspohn Modern Classics-to-be? Other Cars 33
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
M Modern Parts & Service Spridgets 21
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
Healey Nut Modern accoutrements Austin Healey 23
rjc157 Modern Radio Austin Healey 12
glemon Modern Morgan? Other Cars 3
C BMW or other Modern engine-What would you use? Austin Healey 33
Sarastro T-Series Modern Electrics for a TD MG 9
M_Pied_Lourd TR2/3/3A Modern Paint Reference Numbers Spa White Triumph 7
5 Modern [Burlen] SU fuel pumps Austin Healey 7
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
rjc157 modern radio Austin Healey 5
Bradhowesable TR2/3/3A Modern audio in a Tr3A? Triumph 13
aeronca65t "Modern" classic British Motorbikes 4
K Modern Epoxy instead of Welding? Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
K TR2/3/3A Modern Fuse Box on a Tr3? Triumph 7
drooartz Removing modern radio MG 5
cbrvfr Running modern accessories with positive ground? Austin Healey 4
newmexTR3 TR2/3/3A TR3 & Modern Art converge Triumph 5
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
dougie "Modern" Healey Commercial Austin Healey 3
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
bighealeysource Modern color code for MG red MG 3
F Old Cars, Modern Radios Triumph 15
jhorton3 Modern Radios Spridgets 10
prb51 Modern Starters on Tr's Triumph 10
S Modern day Spridget? Spridgets 8
MTribe modern paint code for Signal Red? Triumph 5
A Old English white modern equivilent? Austin Healey 12
John_Mc Modern marvels Triumph 2
R6MGS *modern* cars.....rant Other Cars 21
7 How often do you change... [on a modern car] Restoration & Tools 8
MadRiver Modern or rebuilt alternator? Triumph 14
Thor Modern temporary spare tire that might fit 1500? Spridgets 0
