Engine Hoist Bracket
vping
Bronze
Check out this simple bracket i just made from 1/8" x 2" angle & a 2" exhaust clamp. https://www.villagephotos.com/pubbrowse.asp?folder_id=1561216
Had to move an extra sprite engine from the garage out to the spare roller & then pulled my Midget engine. It only took about an hour tops, with my daughters. I just picked up the engine hoist from pep boys. Works great. I am on my way!
Matthew E. Herd
That looks like a clever idea. I don't quite see how it's held down by the valve cover studs.
jollyroger
Oh yea, I have been doing that for years. I even have one for a big healey. You can even have lifting points in a couple of spots for use based on whether or not you are pulling the transmission too.
vping
vping
Bronze
Just remove the valve cover & re-use nuts. They are actually hollow bolts that screw onto existing studs. The two holes in the center are clearance holes for the other 2 studs that hold the valve train down. Each of these studs is @ 3" on center so it was easy to make. The only change I would do in the future is to use 3/16" angle instead. There is slight distortion in the bracket but very minor. I used it twice in the same day & no problems.
J For Sale Hoist and engine stand Triumph Classifieds 0
D engine hoist Austin Healey 11
R engine removal- where to connect hoist? Austin Healey 16
T engine hoist Austin Healey 14
B TR2/3/3A Pulling engine & trans on TR3B - hoist attach? Triumph 6
Morris Engine hoist... Spridgets 25
1 MGB-GT Engine hoist/crane boom length? MG 17
S Engine Hoist Restoration & Tools 13
Mickey Richaud Engine Hoist Restoration & Tools 17
drooartz Engine hoist--buy or rent Restoration & Tools 11
beez Lifting body with engine hoist Triumph 4
Basil Engine hoist info Restoration & Tools 5
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
