Source for spark plug terminals
Whitephrog
Anyone have a source for right angle spark plug terminals that were original to Bugeyes between engine number 9C-U-H 4796 (September 1958) and 9C-U-H 25484 (October 1959). Horler says that they were copper. The concours guys "Originality Guide" says that they were brass.
dklawson
Sorry Ray, I don't know what those parts look like. However, on another board I recently posted a link to a site in the U.K. that has a lot of period correct ignition parts. Take a look at the web site link below. Maybe they have what you want or can get it for you.
https://www.gsparkplug.com/shop/
rkep01
Ray, check out #21 on AH Spares - electrical, ignition. https://www.ahspares.co.uk/en/products/default.aspx They look like they may be rubber covered, but you might be able to cut the rubber boot off. Email them to find out what material they're made of. I have the originals from my engine #9C-U-H 39187, and after using Brasso to remove the tarnish, they are definitely copper. They may have used both copper or brass, depending on which was available at the time or which vendor they were using.
W
Whitephrog
Could you make a couple of photos so that I know exactly what I'm looking for? There is a photo in Horler's book but it's too small to get much detail.
rkep01
Here it is, Ray. I have another photo, but for some reason the board is not allowing me to post it in this reply, so I'll make a second reply with it attached.
rkep01
Here's the second one.
AN5Sprite
Moss #171-626 looks like the above. I think. I ordered a set at one point and decided against using them. Sent them back. This was 5 years ago so I could be misremembering and/or they could have changed their supplier by now...Worth a look.
jlaird
It surely was and we covered em with a rubber boot.
Nelson Source for washers Spridgets 4
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
