TR2/3/3A TR2/TR3 spark plug gap setting??
TimK1955tr2
Hi, I am curious what spark plug gap I should run on my 1955 TR2...
The Moss catalog specs section states .025 for all TR2/TR3/TR4 and original manual and Haynes states .032 for TR2/TR3 and .025 for the TR4.
I recently installed new plugs set at .032 but had a lot of carbon on the rotor and distributor contact, as well as the points. I have developed a very slight miss even after cleaning everything up.
Should I set it to .025 or at least a bit smaller than .032?
Can carbon build up on the rotor and points be linked to the plug gap?
Thanks for any thoughts!! Tim
CJD
Hey Tim,
Use .025". The voltage in the system is only as much as is required to jump the gap. If you increase the gap, the voltage required goes up exponentially. So yes, larger gap means higher voltage, which means faster wear to the parts.
John
TR3driver
Great Pumpkin - R.I.P
The Haynes manual has a lot of misprints (even different misprints in different versions of the manual).
I agree with John, set the plugs to .025" as given in the owner's manual.
Since you have run the wide gap until it caused problems, I would consider also changing the rotor and distributor cap; at least as an experiment. The extra-high voltage can sometimes force its way through the inside of the plastic, leaving a trail that makes it easier for the next spark to follow the trail instead of jumping the plug.
There is a copy of the owner's manual in the reprint of the factory workshop manual, both of which are good things to have on hand. PN 502602/SC at
https://trf.zeni.net/TR2-TR3Handbook/35.php
Or there is a PDF scan at https://docs.google.com/open?id=0B2H2NJt34OffYWZiN2VlZGMtNTkxMi00NGUzLWE4NzMtMGRkODRkYzU3MDU1
(download to your hard drive, it's too big to look at over the web)
T
TimK1955tr2
Hi, thanks for the fast answers!
I do have the new ignition parts on order already, it was time regardless. The extra gap was really hard on the points too.
I was confused because the original Triumph manual does spec .032" for the "Champion L10S" plugs, that second link like Randall posted above has it on page 65.
So basically all the manuals I have, original or not, spec'd .032 but just happened to browse the Moss catalog and noticed the .025 while I was thinking about the excess carbon on the rotor, oh well.
I will go with the .025, the .032 even looked too big now that I think about it...
Thanks again, take care!!
TR3driver
The wide gap should not have had any effect on the points. Is there any chance you have the wrong ignition coil?
Geo Hahn
Or have the coil connections reversed for the polarity of the car?
T
TimK1955tr2
Hmm, the coil does read 2.2 ohms between the two outer connections, is the coil failing or the wrong ballast? Factory spec is between 3.1 and 3.5 ohms.
The car is positive ground, should the + side of the coil be attached to the distributor or to the wiring harness?
Thanks again guys!!
Geo Hahn
TimK1955tr2 said:
Hmm, the coil does read 2.2 ohms between the two outer connections... The car is positive ground, should the + side of the coil be attached to the distributor or to the wiring harness?
Sounds to me like the wrong coil with that resistance.
White wire (wiring harness) should go to the - post, White/black (distributor wire) on the +. The engine will run fine if that is reversed but it will greatly shorten points life.
JohnB
Bronze
Interesting........
My original TR2 factory service manual calls for .032"
but my original factory owners instruction booklet, that came
with the TR2s, specifies .025" instead. So even Triumph had
mistakes in their info.
Me I've used the latter with no problems.
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
Rhodyspit75 TR2/3/3A TR3 & TR2 parts Triumph 0
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
AngliaGT TR2/3/3A New Windshield for TR2,TR3 $150 Triumph 2
mountainman TR2/3/3A TR2-TR3-TR3A Top Question Triumph 12
HerronScott TR2/3/3A Cutaway TR2-TR3? Triumph 1
M TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!! Triumph 4
beaulieu TR2/3/3A This time the TR3 is one, or maybe a TR2 ! Triumph 12
gsalt57tr3 TR2/3/3A TR2/TR3 grill surround on eBay Triumph 3
TRJohn TR2/3/3A TR2 TR3 master cylinders Triumph 2
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
