TR2/3/3A TR2/TR3 transmission dip stick access
RonR
Folks,
Does the rubber grommet sealing off the hole in the transmission cover go under the carpet or does the carpet cut around the hole with the rubber grommet exposed on the inside of the car?
Thanks.
Ron
mrv8q
I've only seen carpet covering the big rubber grommet in the gearbox cover, except for cars that have no carpet at all..
mgedit
I think the grommet is under the carpet. At least that is how mine is. Cheers, Mike
sp53
I have seen early cars with the plug showing, and I have heard that the carpeting was an extra and not from the factory, maybe the dealer. But then again, I have heard that carpeting was installed by the factory, but then again, I have only seen pictures of the plug exposed, and I believe they were a TR2.
CJD
That's my impression...the early cars had the grommet showing, but all later cars did not.
Geo Hahn
Without a dip stick you fill until oil runs out of the fill hole. The you're done.
To check I use a length of wire (a white insulated wire from a piece of Romex) bent and inserted into the fill hole as a sort of dip stick.
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
S TR2/3/3A tr2 and tr3 back trim above the back cover Triumph 0
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
Rhodyspit75 TR2/3/3A TR3 & TR2 parts Triumph 0
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
AngliaGT TR2/3/3A New Windshield for TR2,TR3 $150 Triumph 2
mountainman TR2/3/3A TR2-TR3-TR3A Top Question Triumph 12
HerronScott TR2/3/3A Cutaway TR2-TR3? Triumph 1
M TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!! Triumph 4
beaulieu TR2/3/3A This time the TR3 is one, or maybe a TR2 ! Triumph 12
gsalt57tr3 TR2/3/3A TR2/TR3 grill surround on eBay Triumph 3
TRJohn TR2/3/3A TR2 TR3 master cylinders Triumph 2
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
A Wanted Girling Axle for TR2 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S TR2/3/3A tr2 Triumph 18
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
