TR6 Spark plug gap
bonzocfi
Member
I read somewhere that if you have electronic ignition/super coil that the spark plug gap should be .030-.035. Is this correct?
Gliderman8
I have the pertronix and have my gap set at .030
poolboy
Hey again...
It's more the type of coil that allows wider gaps...But when I had a Pertronix Ignitor and a standard coil in my 74, I had no misfires with my Champion RN12YC spark plugs gapped at .035.
I'm back to points now with a Bosch Blue coil and when I was using the RN12YC I had no misfires with a .032 gap.
If you start getting misfires at high rpms, it could be because you have too large a gap for the spark to arc.
poolboy
I tried 9's but I found them a little cold and tended to foul, especially if there was much prolonged idling.
At sustained high speed, they were OK...12's won't foul even if you find you're burning a little oil.
K TR2/3/3A Spark Plug Gap? Triumph 4
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
B Spark plug gap Triumph 4
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
R spark plug gap with pertronix ignition and coil Spridgets 6
vping Recommended Spark plug gap MG 26
H Spark Plug Gap Austin Healey 3
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
