spark plug gap with pertronix ignition and coil
recordsj
I have a 1500 mg midget. Installed a pertronix ignition and pertronix flamethrower coil. I have heard that when going to electronic ignition the spark plug gaps should be wider. Does anybody have more info on this have a good idea of what I should set my sparkplug gap at?
On the pertronix instructions, all they say that the manufacturers recommended gap should be used. Anybody have any info on why they say this?
Dave Russell
Yoda - R.I.P
I think on the small Lucas distributors the rotor insulation & internal cap spacing are marginal to withstand the higher voltages required by wider plug gaps.
The wider the plug gaps, the higher the required firing voltage & the more likely that there will be high voltage insulation breakdown or cross firing. Note that later model distributors, intended for higher voltages, are larger & have more insulation in the critical areas.
Just an opinion,
aeronca65t
I'd agree with Dave's comments, but just to let you know, my 1500 racer is running plug gaps of 0.035" with a Pertronix setup.
I am running this with a 25D distributor (not the stock 1500 model) so I could use a screw-lug, side terminal cap (this is the old-style cap with the plug wires coming out "sideways"). I choose this cap since I was using solid core (copper) plug wires.
I am running a large American coil ("Standard" brand--intended for a '60s Chevy) that I bought at a local auto parts store for about $15. I have an external ballast resisitor. Produces an excellent spark.
After about 5 years with this, no problems.
You could experiment, but I'd guess that you could easily run 0.030" plug gap if your wires/cap/rotor are in good shape.
R
recordsj
does anyone know of any issue with using standard sparkplug wires with the pertronix electronic ignition with the flameflower coil combination? Or does some other special kind of sparkplug wires do better?
What about sparkplug type to use with this combination of pertronix and flamethrower?
K TR2/3/3A Spark Plug Gap? Triumph 4
B TR6 Spark plug gap Triumph 5
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
Jim_Newman Spark Plug Gap Austin Healey 9
B Spark plug gap Triumph 4
F Spark Plug Gap Recommendation Austin Healey 3
R incease spark plug gap with pertronix Spridgets 3
MGTF1250Dave Spark plug gap with high voltage coil Triumph 17
VelodromeRacer Spark plug gap/heat range? Racing 8
vping Recommended Spark plug gap MG 26
H Spark Plug Gap Austin Healey 3
T Pertronix = greater spark plug gap? Triumph 4
Woodie spark plug gap Spridgets 9
vping Spark Plug Gap MG 13
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
