TR2/3/3A Spark plug threads
sp53
Spark plug threads, number 4 plug hole has some drag or minor cross threading on the last couple of threads. I just find it unsettling mostly because I pull the plugs a lot to evaluate things. When I pull number 4 out, there is resistance at first and resistance at the end going in plus I can see scaring on the spark plug’s thread when removed. I was going to chase the threads with a tap with a glob of grease on the threads of the tap like I was shown to catch any metal, but I do not seem to have that tap. Moreover, I always like to hear from others on something like this. Oh and thanks Tex for the oil suggestion; it does seem like a waste to drain so quickly. The oil and exhaust are or so clean on this rebuild that I like to contribute it to that 4th ring below on the piston, but it is still too early to tell anything and pride doesth proceed the fall.
Geo Hahn
something we did when chasing those threads on a friend's engine was to take a length of thin rope, smear grease on it and stuff it into the cylinder with the piston an inch or two down. after the chase we retrieved it with forceps. grease on the tap too as you noted.
the tap is, of course, available most anywhere - I think I got mine at Ace hardware.
dklawson
The auto parts stores will have a thread chasing tap jut for this task. Unfortunately, most the clerks won't know what you are looking for. At places like Advance Auto they are up front in the tool section. Do NOT let them sell you the HeliCoil thread repair kit, that is not what you need. You just need the thread chaser tap. It will have the large 18mm tap on one end and smaller 14mm tap on the other with a hex in the middle to drive it with a socket or box end wrench. Pack the tap with grease and use your wrench to run the tap in and pull it back out.
Sidebar note: The 18mm tap is the same thread size used on oxygen sensors for modern cars. If you are ever working on your modern car and find the O2 sensor has damaged threads, the spark plug chaser is a must-have to clean up the bung on the exhaust pipe to install a new sensor.
Picture below from Advance Auto. Their part AC544, $8.50 as of 12/7/14.
karls59tr
Bronze
While we're on the thread chasing subject does anyone know what size would be used on the oil pan drain bolt hole?:indecisiveness:
martx-5
IIRC they are 3/8"-18 NPT...tapered pipe threads.
S
sp53
I like it Geo, smart. So the threads are metric? That is what confused me. I was thinking they would be 9/16 or something, but I could see that my 9/16 tap was just enough wrong to be a real problem. I have done it before on aluminum head many years ago, but I cannot find the tool, and I think it was metric.
TR3driver
Great Pumpkin - R.I.P
Geo Hahn
...So the threads are metric?...
for reasons I have never understood, plugs and tires seem to be both 'inch' and 'metric' irrespective of the system in use in the country of manufacture at the time.
plugs: metric thread but the reach is stated in inches
tires: metric width but the rim diameter is stated in inches
I suspect the French are behind this but have no proof.
dklawson
Also FWIW, there are other styles of spark plug/O2 thread chasers available. Eg
https://www.sears.com/lisle-limited-access-spark-plug-chaser/p-SPM198327946?prdNo=44
There are indeed other tap styles such as the one Randall posted a picture of. When I needed one quickly I was only able to find the double-ended type tap locally. With this knowledge, SP53 (the OP) can look for either type to address the cylinder head threads on his car's engine. Just don't be talked into getting the HeliCoil kit which (based on the description of the problem) is not needed.
CJD
Hey Steve,
I've been pondering your situation, and I think if I were in the same position I'd pull the head to chase the threads. The problem is, no matter how careful you are, there is always a chance of getting metal shreds in the cylinder. I just picture those, wedged between the piston and cylinder sleeve, grinding away.
If it were An older engine that was already installed in the car, I'd lean towards taking the risk of chasing in place. But not for a brand new rebuild, still out of the car.
Anyway, that's JMHO. I'd pull the head so I'd never have to worry about it again.
R BJ7 spark plug threads Austin Healey 17
Jer chasing spark plug threads on head? Spridgets 8
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
Musicman Spark Plug Wires Triumph 10
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
T Normal/good OHM resistance through spark plug wire Triumph 17
M Carbon fouled spark plug Triumph 27
M Spark plug heat range Triumph 4
J Spark Plug life Triumph 24
W Oil leak around spark plug Triumph 6
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
tahoe healey Champion spark plug testor Restoration & Tools 25
PAUL161 Spark Plug Cross Reference. Restoration & Tools 1
