M
Member 10617
Yesteday I took my car into the shop for my "Spring Tune-Up." (Someday soon I'll know enough to do this myself.)
The mechanic installed new Champion spark plugs and adjusted the valves.
But as the mechanic had not applied anti-seize to the plugs, I decided to remove them today and apply the anti-seize myself. Here is what I found: plug #1 (from the front) was carbon fouled, but the other plugs were normal (according to my plug chart).
What could be causing plug #1 to carbon foul? -- bad plug? incorrectly set valves? some other reason? all of the above?
And is there something I can do to correct this without taking it back to the shop? Or should I just clean the plug from time to time and ignore the problem.
BTW: The engine was completely rebuilt 9 months ago and, of course, had a complete valve job done to it.
