Wedge TR7 fuel in carbon canister-twin carb model
johnrip
My 1980 tr7 is running well, but the bottom carbon canister (Emissions canister), by the radiator, is filling with raw fuel. I am not sure how long this took, but what would cause this? Any ideas?
TR3driver
Great Pumpkin - R.I.P
Probably a slow leak at one of the carb float valves (assuming you have carbs). The float chambers vent through the canister when the throttle is closed.
Check your oil too, as its possible for the excess fuel to get into the engine as well. When I had the same problem on a Stag, I accidentally left the key on and it hydrolocked the motor!
johnrip
johnrip
Thanks TR3driver. So if I remove the carb vent tube, and directed it into a pan, let the the car sit, I should see fuel in the pan in the morning? What does the key have to do with it, I have a mechanical fuel pump? I have seen some fuel in the oil as well. This seems like it is helpful...thanks...John
TR3driver
Fuel evaporates pretty fast when exposed to the air, and my guess is that you're getting only a little bit each time you shut the engine off. So instead of a pan, maybe try tying a Baggie to the line.
Your mechanical pump will only pump a little bit after the engine is shut off, one stroke or less depending on where the cam lobe is of course. But Stags came with electric pumps and no interlock to the engine running, so it will continue to pump as long as the key is on.
johnrip
johnrip
I dont see much while the car is running, or after it sits. I did find that 10 hours after I ran it, the rear carb bowl had fuel on the bottom of it. Not much, but there was seepage. Do you think this makes sense for a leaking float valve. Is thee some sort of bybass valve?
Deleted member 8987
Couple of other things. Sometimes the pipe back to the tank has an issue....and hot outside temperature can push petrol into the canister. But...the purge solenoid...does it work, is it connected?
Deleted member 8987
Direct TR description on TR7. I thought there was a solenoid valve, but maybe that's a TR8. You may want to pop the line from the tank off the canister and let it drip once you park.
The constant depression (vacuum source) should draw all that liquid fuel in the canister back into the inlet manifolding.
Evaporative Loss Control System
The function of this control system is to prevent fuel hydrocarbon vapours from entering the atmosphere. This is achieved by providing no direct external fuel tank breathing and venting the tank through two adsorption canisters located in the engine compartment.
To prevent the canisters flooding due to thermal expansion of any fuel in the tank, the tank filler neck is entered well down into the tank, and a pipe let into the tank at maximum fuel level vents into the filler neck to
allow for fuel expansion. A liquid vapour separator is incorporated into the fuel tank vent pipe to reduce the quantity of vapour passed to the canisters.
Any fuel vapour is purged from the canisters once the engine is running by means of a connection to a constant depression region between the air meter flaps and the throttle butterfly.
poolboy
That could be a factor
The TR7 does have an Anti Run-on Valve that could be drawing an overabundance of fuel within the carburetor float chamber into the Carbon Canister.
johnrip
johnrip
So, if I follow,...My issue could be the float valve is stuck open, flooding the bowl, and the evaporative system could be drawing the excess gasoline into the canister, and likely my engine oil. If the carb issue is resolved, the evaporative system could still be operating properly? Could there be another cause of the bowl seeping gas? The evaporative system malfunction wouldn't flood the bowl...right? PS the anti run valve is connected to a small hose that it connected to the top of the intake manifold, then to the antirun valve then to the first canister.
poolboy
That is pretty much the scenario I envision. I've seen it on TR6's which have the same ARV plumbing and same basic ZS carbs.
That sounds like it might be correct plumbing for the ARV.
If you follow BH19, BH21, BH16, BH3 and BH4 you'll see the basic ARV plumbing.
https://trf.zeni.net/TR6bluebook/49.php
When you turn the ignition key to OFF, killing the motor, the ARV gets power from the ignition switch. The ground on the ARV comes from the oil pressure sensor and during the few seconds that it takes for the OP to drop, the sensor provides that ground, completing the circuit that opens the ARV to the manifold depression. During that interval the plumbing is open from one of the carbs' float chambers vents, to the carbon canister, to the intake manifold.
Just to be clear, each of your carbs have 2 float chamber vents.
This one identified in red is the one for the ARV plumbing when the engine is idling. The other vent for higher speeds is the round brass lined hole on the carbs' air box mounting flange.
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
S Wedge TR7 Fuel injection problem Triumph 3
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
A Wedge TR7 Fuel Pump Triumph 0
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
Andrew Mace Wedge TR7 fuel and temp. gauges not working Triumph 28
MCNX_BFF Wedge TR7 brake fluid leak--bonus: fuel leak, too! Triumph 9
johnrip Wedge tr7 fuel pump Triumph 3
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
RSMTR8 Wedge TR7/8 Unleaded Fuel Badge..... Triumph 1
S Wedge The TR7 Fuel Gauge Follow-up Problem !?!? Triumph 12
S Wedge Help with TR7 Fuel Gauge replacement Triumph 3
W Wedge tr7 fuel delivery Triumph 18
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
