Wedge TR7 brake hard and flex lines - fittings
TR Craving
Hi all,
I will be replacing all the hard and flex lines on my TR7. Before I start bending and flaring the hard lines and ordering the stainless braided flex lines, can anyone confirm that all the fittings on the car are ISO bubble flares? Are there any fittings that are 45 degree double flares?
Thanks
TR
sp53
I have never own a tr7, but most big cities have hydraulic repair shops that specialize in fabricating hydraulic fittings and lines by duplicating the original. The times I have had a weird challenging flare that I could not duplicate, I take it to them. Often the one is end made up from their supplier and the length and the other end needs to be made to fit. tr7 is probably a common thread i remember i had to convince them tr3 was standard thread. they have those rubber heating and criping tools and braided lines
steve
T
TR Craving
Thank you for your response and insight, Steve. They should be common thread. I'll have to confirm that. I'll see if there are any hydraulic shops in the area.
Thanks
TR
steveg
TR,
This inexpensive Eastwood tool makes what Moss calls "universal" flares which will work in either bubble or double applications.
A
akbaradeli
Hi buddy,
There are two basic types of flares used on OEM automotive brake systems throughout the world. The SAE/double (inverted/45degree) flare and the DIN/ISO bubble flare. We will refer to them as SAE or DIN flare. The most common is the SAE flare. Typically found on all American and Asian cars, but the European style DIN flare is appearing everywhere now.
Never use a single flare on automotive components. The SAE/double flare standard is remarkably tolerant of production variations, but the assemblies must be the same standard. Single flares are never allowed on steel brake lines.
mastaphixa
Bronze
+1 on the flaring tool shown above. I used that tool to make all the double flares on my TR3 when I remade my brake lines. Works beautifully on Copper Nickle 3/16 lines.
Sarastro
Dunno about the TR7, but the TR4/4A uses a mix of 45-degree double flares and Girling bubble flares. So I'd prepare for the same kind of thing on any other TR.
T
TR Craving
Thank you everyone for taking the time to help me with this. Steve, that tool is exactly what I need and a lot more afforadble than other similar but single-type flaring tools. Mastaphixa, thanks for that.
Akbaradeli and Sarastro, that gives me a good idea what the flare will need to be.
Cheers everyone!(y):giggle:
T
TR Craving
TR,
View attachment 70059View attachment 70060
Hi Steve, I just went to the Eastwood.com site and searched the 31244 number and got a different price unit? Is this the same website that you refer to? Or did I search the wrong item?:(
TR
T
TR Craving
Ha Ha yes you are so right! Inflation really is skyrocketing these days, and it's not just gas prices and tools! Hold on to your wallet... if you can. Maybe this is just the beginning?:cry::eek:
mctriumph
All repairs to a 7/8 start at the wedge shop. Replace the front brakes with the Wilwood conversion
This will likely save your life. Comes with the steel flex lines (front) add the one in the rear and the Tr7
is now down to it's dodgy rear brakes. Good luck with them. GOK who can fix these suckers.
We replaced these with disc brakes on the race car .A hybrid of the front tr7 calipers you just removed
and a Mazda rear brake rotor. You lose the E brake completely, but can now brake with a Porsche.
MD(Mad dog)
T
TR Craving
Thanks MD, great advice. The price of the WS Wildwood brake kit means it can't be done for now, though. It won't be going on the race track :( so a more econo option is needed for now.
Your suggestion of the old front calipers on the rear with Mazda rotors is an excellent idea! Thanks!
TR
johnrip Wedge TR7 Brake squeal Triumph 1
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
A Wedge TR7-TR8 brake rotors Triumph 17
Got_All_4 Wedge TR7 brake booster Triumph 18
Got_All_4 Wedge TR7 rear brake questions Triumph 9
A Wedge 1980 TR7 Brake master Question Triumph 5
mgbmedic Wedge TR7 Rear Brake Shoes Triumph 7
johnrip Wedge TR7 brake master reservour Triumph 3
MCNX_BFF Wedge TR7 brake fluid leak--bonus: fuel leak, too! Triumph 9
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
tr7andtvr Wedge TR7 Range Rover Master Brake Cylinder Swap? Triumph 1
philman Wedge tr7/tr8 brake differences Triumph 2
T Wedge TR7 Brake ajustment Latest Triumph 0
S Wedge TR7 Brake light won't go off Triumph 8
J Wedge looking for resevoir for brake master cylinder,tr7 Triumph 1
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
