Maybe, but a little fabrication might be required.. You can install a Rover SD1 master. It has a slightly larger bore and the brake lines come out the other side, but it will bolt up. Lately alot of people with uprated brake calipers have been looking at installing masters with larger bores. A buddy of mine just installed a booster and master out of a Chevy. It looks like crap, but it pushes more fluid and has less brake pedal travel. Many brake masters have the same mounting hole spacing and the same external bores dimensions. This allows you to bolt them directly to our booster as well as many others. The only variable would be push rod length, but you can use an adjustable one.
