Wedge 79 TR7 no start
ODAR
Working on a 79 TR7. Vehicle came to me as a no start. Found out the Lucas AB14 module had died. Replaced with electronic ignition, Pertronix ignitor 1 and new 4 ohm coil. Got spark figured out, and have good spark to all 4 cylinders, with new spark plugs, wire, cap and rotor. As far as I can tell, I am getting fuel through the cylinders. However, I can't get the car to start. Not even with starting fluid. Anyone have any ideas? If I need to include any additional info, let me know and I'll get it as soon as I can. Thanks in advance.
NutmegCT
You have air, fuel, and spark. But are they happening at the right time, in the right order?
If you crank the engine for a few seconds, pull a plug and see if it's wet with gas. If so, then it sounds like the timing is off - way off.
If the plug isn't wet with gas, then you've got a fuel flow problem.
Hope this helps.
Tom M.
O
ODAR
Hope this helps.
Tom M.
I checked timing and firing order, everything is correct. Checked compression, have between 60 and 75 psi across the cylinders. Believe the valve seats may be bad. Waiting to hear from the customer if they want us to tear it apart to confirm.
NutmegCT
And when you crank the engine, do the plugs get wet with gas?
Valve seat problems wouldn't likely prevent the engine from firing at least a few times.
poolboy
Low compression and if the gas is old..that would be a bad combination
mctriumph
When you find out it is toast(as I think) come to Topeka and pick up a "ran when pulled" motor
from a 1980. 150$ I will help you load it and provide the beer! Has a new alternator the car died
when the fuel tank bled out.
Mas dog
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
S Wedge TR7 won't start -- arrggh Triumph 22
S Wedge Need Help Badly! - New TR7 Won't Start! Triumph 11
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
K Wedge TR7 Project Triumph 10
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
