    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Wedge Looking at a '80 TR7 ......
AC Orange
Going to look at an '80 TR7 convertible in a couple days and have an engine question. It's a 2 owner car in very excellent original condition. However, it has 98k miles on it and the owner says the engine has never had anything major overhauled on it. He believes the head has never been off and it's the original head gasket and even the timing chain may be original. I'm not as concerned about something like a timing chain as that's something I have done on several engines of various manufacture in the past. But I'm concerned about the head. I've heard of quite a few warped heads on these engines as well as blown head gaskets. I've also heard that the heads can be real buggers to get off the block ?
Should I be concerned about head issues and repairs to them ? How about the rest of the engine ? The owner said that proper maintenance has been done on it through the years and has service records. Even so, can you guys give me advice on stuff I could expect on an engine with that mileage ? Thanks in advance......
trglory
The head is aluminum and if you service it properly it will be just fine. But if you abuse it, it will warp. The rest of the story is that the head studs are not mounted perpendicular to the mounting surface so it can sometimes be difficult to remove the head; recall that steel and aluminum do not play well together so corrosion around the studs can compound the problem. The Triumph Wedge Owners Association designed and built a head removal tool that makes the job much easier and they loan it out to club members. There are many good reasons to join the association but that one perk alone is worth the price of admission.
A
AC Orange
Thanks for your reply. So it sounds like it would not be too bad with the head removal tool. I feel a little better knowing about that.
Any thoughts regarding the longevity of the engines used in the TR7's ? If the engine has had proper maintenance, how many miles could one typically expect to log before a major rebuild ?
Got_All_4
I wouldn't worry unless you notice a problem. Maybe there is a such thing as a good one but if it's not broke don't fix it. Soon after I bought mine I took it for a good drive, let it idle a bit to get it hot and torqued the head. Did it again about 5k later. So far so good. Mine had over 100k on it when I bought it but I know the engine was out and some kind of overhaul was done to it. I've talked to owners that told me they re-torqued the head at every oil change. A bit extreme if you ask me but I do remember the second time I did it a couple of studs needed a slight tightening.
trglory
Hard to say.....all I can tell you is that I sold my TR7 about 5 years ago to a fellow club member when it had 128K miles. He is still driving it regularly to club events and has never had a problem. That car is a late '81 with fuel injection so I don't know if that is representative of the breed.
waltesefalcon Wedge Looking at a TR7 Triumph 6
bgbassplyr Wedge Looking for a TR7 ? Triumph 8
T Wedge any one looking for a nice tr7 Triumph 1
T Wedge Nice looking TR7 in Sacramento Triumph 8
AngliaGT Wedge Looking For TR7 Trim Pieces Triumph 3
PATR8 Wedge Looking for a Small TR7/8 Gas Cap Triumph 9
J Wedge looking for tr7 ground effects kit in usa Triumph 1
J Wedge looking for radiator for tr7 Triumph 2
W Wedge Looking to buy TR7 - opinions please. Triumph 20
J Wedge looking for resevoir for brake master cylinder,tr7 Triumph 1
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
