Wedge Looking at a TR7
waltesefalcon
I'm looking at a TR7 spider. I'm not terribly familiar with the TR7 so what are some of the things I should look for with this car?
first thing to look for is rust. slide the seats forward and lift the carpet inspecting the seams below the seat where the rear axle control arms mount, look under the spare tire, and look down the sides of the trunk just behind the wheel wells. If the seller will let you, bring a compression tester with you (you can pick up a cheap 'universal' kit for like 30$ at harbor freight) and do a quick compression test on the motor. All the cylinders should be within 10% or so of eachother, and this should tell you if the head gasket is in ok shape.
Depending on how much of a stickler you are for originality, the spider edition should have the same alloy wheels as the TR8s but they are silver painted, and the part number stamped in each wheel has an S at the end of them.
So the alloy wheels are painted silver? That's a gas, although not terribly surprising; I know Mercedes used to do the same thing. I'm not a huge stickler for originality, but I'll go ahead and check the wheels, where are the part numbers stamped? Don't worry, I always take my compression tester when I check out a car.
Buy it! You know you wanna become a wedgehead.
Also look for rust on the tops of the strut towers. If drivable check for a shimmy in the front end at 55mph. look for coolant on top of he block. Post some pics and that will help us. A lot of Spider owners are very proud of the cars and they did have some upgraded features like the black paint, interior, wheels and maybe fuel injection. they reflect it in there price but remember it's still a TR7. I don't remember for sure that spiders had the gray striped mohair seats or the red plaid. If the plaid TRF has a OEM set for sale.
They had a black and gray striped material, apparently not very durable because few originals seem to have survived. The TWOA is looking at getting the material made again. The carpet was also a much thicker gray shag carpet than standard.
If you're not sure whether it's a true Spider, check the ID plate on the driver's door. It should read "PMA" for paint code and "RAF" for interior. Also, I think the dash was black rather than the charcoal for all the other Wedges.
A Wedge Looking at a '80 TR7 ...... Triumph 4
bgbassplyr Wedge Looking for a TR7 ? Triumph 8
T Wedge any one looking for a nice tr7 Triumph 1
T Wedge Nice looking TR7 in Sacramento Triumph 8
AngliaGT Wedge Looking For TR7 Trim Pieces Triumph 3
PATR8 Wedge Looking for a Small TR7/8 Gas Cap Triumph 9
J Wedge looking for tr7 ground effects kit in usa Triumph 1
J Wedge looking for radiator for tr7 Triumph 2
W Wedge Looking to buy TR7 - opinions please. Triumph 20
J Wedge looking for resevoir for brake master cylinder,tr7 Triumph 1
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
