Wedge TR7 rear brake questions
Got_All_4
My 1980 5spd PI Tr7 brakes seem to be less then desirable. I replaced the front pads last fall but always felt that the front brakes were doing all the work. In fact the E-brake would not work. Decided to take the rears off Tuesday and found that most of the moving parts were locked up. Took it all apart cleaned everything. Lube it all with anti-seize and even bought new shoes from Team Triumph. The thickness of the new pads were almost identical to the old ones. Before setting off on a test drive I backup and hit the brakes several times. During test drive 12 miles I'm still not happy with the stopping power of the brake system. Could be a lot better in my opinion. But the e-brake works. Anything I could be missing?
tr8todd
Nope. TR7 and TR8 rear brakes do little if anything because they are designed that way. You would need to change the way the brakes are proportioned front to back in order to gain any significant rear brakes. Without doing such, you will never get the rears to even lock up in a panic stop. At least the ebrake works now.
tr8todd
Yes, you can put a him in there. Ted sells ones that are already done wit an exchange for your old one. Or you can just eliminate the valve and run a tee. Pipe the rears directly and tee the fronts.
philman
I have one of Ted's proportioning valves in my dhc.The rear brakes do grab more, but still don't lock up easily.I occasionally auto cross and it did help with braking control.
Got_All_4
Got_All_4
That's what I'm hoping for. I too want to auto cross at the TRF party this year with it but not use to such week breaking particularly after a front and rear brake job.
Got_All_4
Got_All_4
My Triumph mechanic call me today to see if I had an extra starter for a TR3 around. Told him about my braking concerns for the 7 and he told me when he use to race his Mini to improve his rear breaking he took an adjustable proportioning valve from a Volvo and mounted it in the cotpit where he could adjust the brakes while driving. Were going to trade off some work for my starter. But only after my foot heals. If anyone is interested in the results let me know and I'll post them.
tr8todd
On most cars that is the exact right thing to do. On the wedge, you will probably end up adjusting it all the way so that it doesn't proportion at all. In essence you will be running the rears directly just with a fancy $50 part in line. On the race car, I actually have the proportioning valve in the cockpit, but instead of installing it on the rears like you would on most cars, I installed it on the fronts. By teeing them directly and then stepping down the fronts proportionally, I was finally able to get the rears to lock up if I wasn't careful. My suggestion is to start by just eliminating the stock valve all together and see if your happy with that. If you still don't have enough rear braking, then step down the fronts. If you have too much rear lock up, step down the rears. The best way to check for lock up is take a long sweeping curve in an empty parking lot and then attempt a panic stop. If the car swaps ends, you got too much rear brake. It should just push in a straight line as you brake for safety reasons. If you turn your car into a dedicated track car, then you can set it for max rear braking where it will swap ends if you do something stupid. Threshold braking in a straight line is easy. Threshold braking in a car with an 85 inch wheelbase when the front wheels aren't pointing straight ahead is very difficult if not deadly.
DNK
PHIL- Where the H*E* double hockey sticks you been?
mgbmedic Wedge TR7 Rear Brake Shoes Triumph 7
tr7andtvr Wedge Tr7/8 rear end ID RKC0100 Triumph 4
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Wedge Rear Disc Brakes for TR7 Triumph 16
D Wedge TR7 High Speed Rear End Triumph 6
T Wedge TR7/8 3.08 rear end Triumph 0
T Wedge TR7 Rear Brakes Triumph 5
KLUTZ Wedge TR7 Rear end wobble? Triumph 8
philman Wedge Tr7 popping sound from Rear Triumph 0
philman Wedge rear disk for a tr7 Triumph 0
D Wedge TR7 rear spoiler/wing Triumph 2
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
