Wedge TR7 Rear Brake Shoes
mgbmedic
I've got an 80 TR7 that has a problem with the emergency brake. It doesn't work. On inspection, the rear brake shoes that are on the car have no provision for the emergency brake. There should be a notch in the shoe for the mechanism to fit. They don't. I ordered new shoes from V-B and they are identical to the pair that are on the car. However, the illustration in the catalog shows the correct shoes. When I complained to V-B, they said I was only one of two complaints in 12 yrs and therefore have no grounds. Has anyone else had this problem?
I suspect there must be some similar Lockheed brake setup -- in terms of diameter and width of shoe but perhaps with a manual adjusting setup rather than the self-adjusters of the TR7. That's the only reason I can think of why otherwise identical shoes might lack the one "notch"? Regardless, I can't say I agree with the vendor's cavalier attitude! :frown:
I got a set of shoes that did not have the notches/mounting holes for the e-brake mechanisms. It does happen but rarely.
What did you do about it? Did you do without e-brake? Does moss or some other vendor have the correct shoe? If anyone has an accident with those shoes from V=B, someone will own a parts store.
Well Im not tossing in any plugs but I got them from teh wedge shop and told them what happened and I got the right one......he opened the box up and made sure they had the right holes/tabs. The other for the $16.00 are now wheel chalks.
Are you sure it's the shoes. I went for a while without my e-brake and it was because I messed up the reassembly....I had brakes but no e-brake.
can't you get the old ones relined? My e-brake wasn't working very well and I figured out that somebody previous to me had the lever on the rear axle facing 180 out (above the rear axle).
I'm sure about the assembly. I'm more upset about the attitude of the parts supplier. I sold the car so I can start on a TR3B project. I want the new owner to be safe as can be in a 30 yr old car.
Got_All_4 Wedge TR7 rear brake questions Triumph 9
tr7andtvr Wedge Tr7/8 rear end ID RKC0100 Triumph 4
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Wedge Rear Disc Brakes for TR7 Triumph 16
D Wedge TR7 High Speed Rear End Triumph 6
T Wedge TR7/8 3.08 rear end Triumph 0
T Wedge TR7 Rear Brakes Triumph 5
KLUTZ Wedge TR7 Rear end wobble? Triumph 8
philman Wedge Tr7 popping sound from Rear Triumph 0
philman Wedge rear disk for a tr7 Triumph 0
D Wedge TR7 rear spoiler/wing Triumph 2
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
