Wedge TR7 High Speed Rear End
Delmon
I need a high speed third member for my 1980 TR7. I am running a 3:96, I need a 3:08, I think that is the highest ratio made. I am tired of running 3000 rpm at 60 mph.
tr8todd
1980's came stock with a 3.45. The coupes had the 3.90s, but I've seen many a car with the rear end swapped out. The 3.08s only came in the 2800 or so TR8s, and the 81 TR7 automatics. Good luck trying to find one. Another longshot would be to find a rear end out of a Rover SD1. You could swap the ring and pinion into your pumpkin. The only problem with that is the parts to rebuild the rear end are even harder to find than a spare 3.08. That is why so many TR8s are running the 3.45, and why so many people are building Ford 8.8 posi disc brake rear ends to stick under the TR8s. The 3.45 will yield about 70 MPH at 3000 RPM in fifth gear.
philman
i picked up a ring and pinion gear from the uk pretty reasonably. i think a 2.86 ratio. crush spacer was the hardest to find.
PATR8
MY 8 came with 3.90 because the DPO thought he was going to be a race car driver then he got married and his wife told him he was going to be an accountant. I drove the 3.90 for a few years but went to the 3.45, it was like adding a 6 gear. It made it so much more drivable
Delmon
I cant use a TR7 trans, im running a Buick 3.1 V6, with a 350 tranny. I might change to a overdrive tranny and help some. I would have to cut the driveshaft again and balance it.
Delmon
I cant use a TR7 trans. I have a Buick 3.1 V6 in car, using a 350 trans. I might switch to a overdrive trans, would have to cut driveshaft though.
D Wedge TR7 High Idle problem Triumph 7
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
K Wedge TR7 Project Triumph 10
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
L Wedge TR7 gasoline odour Triumph 5
