Wedge 1980 TR7 Brake master Question
Aeroweld3033
Member
hey folks does anyone know the bore size of the stock master cylinder on yee ole wedges? or to make my life even easier, does anyone know of any other masters that bolt right onto that booster, theres got to be something! cant find a new Tr7 master for under $200 but im seeing plenty of general spec built ones for around 50 to 80 which even seem better ( bigger bore sizes and casted of aluminum ) but i cant get companies to email me back with mounting dimensions . . . so any help will be appreciated. . not naerly as concerned with originality as i am with getting her on the road
WedgeWorks
TR8Todd has a few options I am sure he would pass on to you. I know of a few bolt on master but have no clue what they are from.
tr8todd
Unless you are changing brake calipers, your best bet is to keep the stock bore size. Bigger is not better. Brake masters are sized according to the cross sectional area of the pistons in the brake calipers and the rear wheel cylinders. Other things come into play such as pedal ratio and brake booster area. $200 is a very fair price for a brake master that you know will work properly and won't require all kinds of other potentially costly mods to make fit. If you are determined to try and use a $50 Chinese master, then take careful measurements of the stock TR7 master and use that as a guide to pick out the new one. Sites like Summit will provide measured drawings of the parts they sell and in some cases application. The biggest issue you will have to overcome is the small size of the opening in the booster that the master inserts into. Most aftermarket MC bores are between 7/8" and 1 1/8'. The castings are too large to fit into the TR7 booster. Bigger MCs are great if you go to larger caliper bores or add rear disc brakes. In those cases, you will want to push more fluid with a given stroke of the brake pedal. You will also need to buy a handful of brake line adapter fittings, and plan on modifying the brake pedal and the push rod. Buy the new one, a good used one, or rebuild the one you have.
A
Aeroweld3033
Member
i understand bigger isnt always better which why im still trying to find out what the stock bore size is for the 7.. . and thanks for the info
tr8todd
Bore size 7/8". Mounting hole spread center to center is 2.25 ". Machined end that fits into booster is slightly less than 1.2".
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
Got_All_4 Wedge Drove a 1980 TR7 today PICs Triumph 16
Got_All_4 Wedge Going to look at a 1980 TR7 on Thursday Triumph 43
mgbmedic Wedge 1980 TR7 Heater Core Triumph 2
G Wedge Need help with 1980 TR7 Triumph 2
bmurphy7369 Wedge TR7 DHC fans, advice on value/feasability of 1980? Triumph 7
M Wedge New Owner of 1980 TR7 Convertible Triumph 8
D Wedge 1980 TR7 Convertible value Triumph 3
F Wedge Background on my 1980 TR7 & current Idle problem Triumph 3
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
S Wedge Potential Buy: Pros v. Cons of 1980 TR7 injected? Triumph 7
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
A MGB 1980 MGB MG 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
Russ80MGB MGB 1980 MGB - No power MG 16
P MGB 1980 MGB Modified Intake Manifold MG 7
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
H MGB 1980 mgb no power from ignition switch MG 23
C MGB 1980 MGB Roadster Tyres UK MG 0
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
BobHaskell MGB 1980 Catalyst sticker MG 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M For Sale 1980 MGB for Sale MG Classifieds 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Spitfire 1980 spit.. 34000 miles unbelievable Triumph 5
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
S MGB 1980 MGB quick question MG 2
RickB MGB 1980 Starter Relay & running problems MG 14
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
C MGB Fairly complete 1980 MGB with O/D in Stanton, CA Pick your part MG 3
N "Ole 19" Freddy Baker 1980 win article?? Jaguar 1
1 1980 Panther Lima restoration project Other British Cars 11
ecurie_ecosse MGB 1980 MGB Running fast. MG 4
J Wedge Rear Brake Drum 1980 TR 7 Triumph 5
AngliaGT .1980 Honda Accord Spotted 4
