Wedge tr7/tr8 brake differences
philman
While rebuilding the master cylinder on my '76 FHC and noticed that the brake booster off my tr8 parts car is much larger than the booster on my tr7. Also noticed that the proportioning valve looked different. The bolt patterns are identical and they fit right in. Just wondering if the larger booster is TR8 specific or maybe the later TR7's got uprated to larger boosters. My FHC already has the TR8 front strut assemblies and brakes.
tr8todd
The TR8 booster is bigger. Not as big as a Rover SD1. The MC is the same. I believe the proportioning valve is the same, but who cares, they are overly biased to the front and should be removed anyway. The front strut assemblies are the same, but the TR8 carries larger rotors, calipers, and pads. The rear brakes are the same except for the early 4 speed cars. Anyone looking for an easy upgrade can switch to Ford Capri calipers and TR8 rotors. The calipers are easier to get than TR8. The pads are cheaper as they are the same as 240Z pads, and they come in and out by removing a pin. Best of all, they bolt right up. I have been running them on my race car for years.
philman
philman
hey, thanks for the info and ideas. i use my fhc as a test bed for mods to try on my dhc. maybe i'll try aftermarket adjustable proportioning valves next.
A Wedge TR7-TR8 brake rotors Triumph 17
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
GBRandy Wedge TR8 [or TR7] Fresh Air Intake Seal - help Triumph 8
johnrip Wedge tr7 tr8 alloy wheel tires Triumph 3
GBRandy Wedge TR8 [TR7] Seat Bottoms Triumph 8
GBRandy Wedge TR8 [TR7] dash & switch pieces Triumph 1
GBRandy Wedge TR8 [TR7] Seat replacements Triumph 6
S Wedge steering gear rack on a tr7 and tr8 Triumph 4
I Wedge Wheel measurements for a TR7 or TR8 Triumph 2
toysrrus Wedge TR7 & TR8 "BIG" write up: Triumph 14
swift6 Wedge TR7 TR8 DVD... Triumph 8
tr7andtvr Wedge TR7 or TR8 Master Cylinder Triumph 7
T Wedge TR7 manual rack into TR8 Triumph 9
T Wedge Need a Triumph TR7 FHC for a TR8 conversion? Triumph 13
T Wedge TR7 / TR8 seat question Triumph 11
T Wedge TR7 & TR8 bumpers / doors / dash parts interchange Triumph 4
T Wedge TR7 & TR8 doors interchangeable? Does year matter? Triumph 2
C Wedge TR7/TR8 seat question Triumph 3
Radford Wedge This just came over on the TR7 TR8 list I'm on. Triumph 0
1 Wedge TR7 and TR8 Engine difference Triumph 9
T Wedge TR8 TR7 windshield replacement Triumph 4
T Wedge TR7 or TR8 A/C drier Triumph 0
V Wedge April Issue AUTOMOBILE: GROUP 44 TR6, TR7 and TR8 Triumph 0
T Wedge Black paint under doors on TR7/TR8 Triumph 5
E Wedge I need some TR7 and TR8 Owners to sound off! Triumph 7
philman Wedge TR7/TR8 LSD Gear Triumph 0
J Wedge tr7 - tr8 throw out bearing carrier Triumph 7
mctriumph For Sale Tr7 engine Triumph Classifieds 2
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
