Wedge TR7 manual rack into TR8
tdskip
Hi guys - a friend from a mailing list just had his TR8 power steering rack give up the ghost. He is wondering if a TR7 manual rack would fit.
Any ideas/experience?
Thanks.
tr8todd
They fit. Most of my 8s end up with manual racks. I like the way they feel better than the power units. You will need to swap out the whole rack, including the lower steering shaft and tie rods. The lower shaft on the 8 is a little shorter because of the control box on top of the steering rack. Toughest part will be removing the power steering pump. The early coupe TR7s had a rack with a quicker ratio than did the later cars. Stick to one out of a later car unless the car is a competition car. With the manual rack, the steering will feel like it does on a TR7- a little stiff for three point turns, but wonderful once you are rolling. It will also save 30 or 40 pounds off of the front.
tr8todd
I see you posted my comment on the TR8 list. I switched internet providers and can't seem to post on the list any more. I still get the list once a day and read it with my morning coffee. I'll spend a little time checking out the dozen or so racks I have around and try to give you the different ratios. Off of the top of my head< I think it is 2.9 for very early cars and 3.5 for rest. I have an early one in the race car, so I'll check that one first. On a side note, I am picking up another TR8 78 coupe today. It needs a full restoration, so it looks like I am about to embark on another labor intensive, money loosing venture.
tr8todd
Just finished counting and here is what I found. TR8 power steering is about 2.7. Rover SD1 is the same, about 2.7. TR7 repair manuals list the TR7 as 3.875. That is what I found on 3 of my racks. The rest of the ones that were easy to get to, were all about 4.6. Seems interesting that all of the books list the TR7 at 3.875 when most of my racks are around 4.6. It would seem that they changed and didn't list it in the factory shop manuals. I am sure that the specs listed in the Haynes manual are just copied from the factory one. Found one thing disturbing. I actually have a slower rack in the race car and a faster one in the street car I'm building. Add that to the list of things I've screwed up. I guess I'll be changing out the rack in the race car. I also have a new old stock rack still in the bubble wrap, but that thing was so stiff I couldn't even turn it. It's going into my buddies car that just came back from being painted, so I'll know about that one when I get around to putting it in. So much for Bill's urbine myth. I guess he just needed to broaden his search data. This is a perfect example of why I have never bought a book about wedges. I'll put them on the shelf if I find one in a car I buy, but I won't waste my money on them.
T
tdskip
Hi Todd - I hope it was OK to post that on the TR8 list. Bill was being cranky - I had a bunch of other guys email me directly who were very appreciative of the info (as was I)!
Any pictures of the new Coupe?!?
tr8todd
I'm glad you posted it. Some day I'll spend some time and get my situation with the list sorted out. Bill and I talk all the time by private email. We have very similar interests in competition TR8s, and neither of us have tons of money to throw away. I am leaving now to retrieve the car. I have to remove three MGBs as part of the deal first. The MGs are rusting into the ground, but have a ton of potential as parts cars. They should help me recoup some of the money I'm spending to buy the eight. I don't know what it is, but I always seem to get involved in deals where I end up with several cars at once. My wife is going to kill me when she finds out I just bought four more cars. I don't think the Bs are long for this world. Maybe take off the wire wheels and an engine or two before sending then to the scrap yard. Cars are $140 a ton here. I should be able to get back the gas and toll money it will cost me to retrieve these things anyway. Pics will follow after I get all of the stuff home.
T
tdskip
Good luck pulling everything Todd.
I can help post the MGB parts on another active MG forum if you want (or suggest you register and list on the mgbexperience.com)
TR3driver
Great Pumpkin - R.I.P
Just a thought ... is it possible the travel is limited by something else rather than the rack, so the published figure is correct once it's installed in the car ?
Or maybe everyone leaves out the stops when they rebuild the rack ? The Stag is supposed to have stops in the rack, but they were missing from the 'rebuilt' one I bought (which also had other problems, good thing I didn't pay very much for it).
tr8todd
Not likely, as I looked at racks that were both in cars and on shelves. Just got home with the TR8 coupe. It is a red, automatic, AC, Webasto sunroof car, built in Aug 77. Seems to be bone stock and very complete, but will need an extensive resto.
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
K Wedge TR7 Project Triumph 10
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
L Wedge TR7 gasoline odour Triumph 5
tr7andtvr Wedge Tr7/8 rear end ID RKC0100 Triumph 4
