Wedge TR7 Fuel injection problem
Silvio
My son was driving down a suburban street in his recently revived TR7 Spider with fuel injection. All of a sudden there were a few pops, then nothing. When he pulled off the road, he discovered huge cracks in the rubber boots that are between the plenum and intake manifold. First, we need new boots to replace the old cracked ones. Then we need to diagnose the problem.
Any thoughts?
Silvio
Dale
I think moss has the rubber boots you need. They have shown up on E-bay from the folks who claim to make them as reproduction parts. The Bently manual is worth the bucks and should contain a section on the FI. It has an excellent diagnostic step by step chart. That is of course if the problem is with the FI. Diagnoses is as with any thing else, spark, fuel, compression. Good Luck and welcome to the forum.
Darrell_Walker
Hi Silvio,
Welcome!
Once you fix what sounds like potentially large air leaks, you may find that is your problem. With a large air leak past the air flow meter, the ECU will see little or no air flowing into the engine, which may cut off the fuel pump right there, but at a minimum will cause it to inject very little fuel.
As a temporary fix, you can wrap them in duct tape.
-Darrell
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge TR7 Fuel Pump Triumph 0
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
Andrew Mace Wedge TR7 fuel and temp. gauges not working Triumph 28
MCNX_BFF Wedge TR7 brake fluid leak--bonus: fuel leak, too! Triumph 9
johnrip Wedge tr7 fuel pump Triumph 3
RSMTR8 Wedge TR7/8 Unleaded Fuel Badge..... Triumph 1
S Wedge The TR7 Fuel Gauge Follow-up Problem !?!? Triumph 12
S Wedge Help with TR7 Fuel Gauge replacement Triumph 3
W Wedge tr7 fuel delivery Triumph 18
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
